POV-Ray : Newsgroups : povray.advanced-users : IsoSurface Help Server Time
10 Jan 2025 06:07:32 EST (-0500)
  IsoSurface Help (Message 1 to 7 of 7)
Subject: IsoSurface Help
Date: 2 Apr 2010 23:20:00
Message: <web.4bb6b3807b9446f84fd370d20@news.povray.org>
Can Someone help me out. I'm trying to figure out the weird coloring on the
lighted portion of the bottom half of the sphere.
The image is at
http://news.povray.org/web.4bb6af70dba6e9c64fd370d20%40news.povray.org
<web.4bb6af70dba6e9c64fd370d20@news.povray.org>
The source is
Source is as follows:
The image is at
The source is
#include "math.inc"
  location  <0.0, 1.5, -4.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#declare num =  8;
#declare fn_theta_deg_of_x_y = function(x,y) { mod(atan2d(y,x) + 360,360) }
#declare fn_block = function(x,y) {
-1*mod(floor(fn_theta_deg_of_x_y(x,y)/(180/num)),2) }
#declare fn_x_y_z  = function(x,y) { fn_block(x,y) }
isosurface {
  function { fn_block(x, y) }
  contained_by { sphere { 0, 1.0 } }
  isosurface [0.0]
  accuracy 0.001
  max_gradient 2000
  pigment{color Red}
Subject: Re: IsoSurface Help
Date: 3 Apr 2010 04:17:47
Message: <4bb6f9ab$1@news.povray.org>
Am 03.04.2010 05:18, schrieb Woody:
When dealing with isosurfaces...
- Try avoiding discontinuous functions like floor(), mod() or the like.
The algorithm doesn't work well with those.
- Make sure your function /crosses/ f(x)=0 (or whatever threshold you
choose) instead of just touching it; it seems to me that your function
never goes below the threshold, so that for some pixels POV-Ray is
convinced that it never even reaches it.
For your purposes, I'd suggest using sin() or cos() to produce the
repetitive banding, instead of the mod(floor(),2) operation.
Date: 3 Apr 2010 08:55:44
Message: <4bb73ad0$1@news.povray.org>
>> on the
Also, using sin() or cos() will greatly reduce your max_gradient and
will probably result in a faster rendering.
Date: 3 Apr 2010 11:13:37
Message: <4bb75b21$1@news.povray.org>
> The image is at
> The source is
> The image is at
> The source is
> #include "math.inc"
> camera {
>    location<0.0, 1.5, -4.0>
>    direction 1.5*z
>    look_at<0.0, 0.0,  0.0>
> light_source {
>    color rgb<1, 1, 1>   // light's color
>    translate<-30, 30, -30>
> #declare num =  8;
> isosurface {
>    isosurface [0.0]
Here, this statement produce an error.
-> No matching } in 'isosurface', isosurface found instead.
Normal POV-Ray never use, nor used, that structure.
>    accuracy 0.001
>    max_gradient 2000
>    pigment{color Red}
Discreete functions like mod(), ceil() and floor() produce extremely
large max_gradient. In fact, it reatch infinity at the discontinuities.
Use something like this instead:
   function { f_sphere(x,y,z,1) + sin(atan2(x,y)*num )}
And reduce your max_gradient to something like 15 to 20
Date: 3 Apr 2010 17:00:01
Message: <web.4bb7ab5c4361fbb7b4bb947f0@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:> >    isosurface [0.0]
Sorry,
You probably guessed, this was from the IsoSurface template, and when stripping
down the code of comments and uneeded information for the posting.
It wasn't in the original file.
Date: 3 Apr 2010 17:05:01
Message: <web.4bb7ad224361fbb7b4bb947f0@news.povray.org>
Have any idea what you might do? The only way I can think to do it with Sin or
Cos functions is with fourier series, but this would require an extremely long
function.
Date: 3 Apr 2010 17:40:00
Message: <web.4bb7b5634361fbb7b4bb947f0@news.povray.org>
Never mind. I figured it out by studying of all things financial derivatives, ie
construction using calls and puts.
