POV-Ray : Newsgroups : povray.advanced-users : What exactly does photons media factor do? Server Time
10 Jan 2025 10:15:16 EST (-0500)
  What exactly does photons media factor do? (Message 1 to 3 of 3)
Subject: What exactly does photons media factor do?
Date: 29 Jul 2008 02:50:00
Message: <web.488ebc7565a7da0085de7b680@news.povray.org>
I was trying to fine tune some photon media parameters (in global_settings), and
tried varying the factor.  There seems to be no visible effect at all, although
the mere inclusion of the parameter doubles or quadruples the render time.  Am
I missing anything?  Am I just using it incorrectly?
Below is a code extract, run with version 3.6.1 with +kff7 and +kff-1.  (I set
the max_steps value low in order to contrast the effect of the factor
parameter.)  CPU time averaged 493 seconds per frame vs 106 seconds without the
factor parameter.  All 8 images are virtually identical.
________________________________________________________________
#if (clock_on) #declare Factor = pow (2, frame_number - 4); #end
#declare R = 0.05;
#declare W = 8;
#declare H = 6;
#declare S = 0.005;
#declare M = 50;
#declare Margin = 1;
#declare v_Source = <W/2 - Margin, Margin - H/2, 0>;
#declare v_Target = <Margin - W/2, 0, 0>;
global_settings
{  assumed_gamma 1
   photons
   {  spacing S
      media M #ifdef (Factor) , Factor #end
camera
{  orthographic
   location -z
   up H * y
   right W * x
box
{  -1, 1 scale <W/2, H/2, R> * 1.001
   hollow
   pigment { rgbt 1 }
   interior { media { scattering { 1, 1 extinction 0.001 } } }
   photons { pass_through collect off }
box
{  <v_Target.x, -0.1 * H, -R>, <v_Target.x - Margin/2, 0.1 * H, R>
   pigment { rgb 1 }
   finish { reflection 1 diffuse 0 ambient 0 }
   photons { target reflection on collect off }
light_source
{  v_Source, rgb 0.5 / R
   cylinder radius R/2 falloff R point_at v_Target
   parallel point_at v_Target
Subject: Re: What exactly does photons media factor do?
Date: 29 Jul 2008 08:43:50
Message: <488f1086@news.povray.org>
Hello,
Funny that you posted this now, I've just been messing with a scene,
trying to tune this very parameter.
The factor multiplies the spacing of photons that are shot into media.
So a factor greater than 1 increases the spacing (fewer photons), and
less than 1 decreases the spacing (more photons).  More photons would
obviously increase render time.  Its possible introducing the variation
has some inherent render time cost, I couldn't say for sure.
I haven't tried your code yet, but my theory is that between your global
spacing and the media max interval setting, you are getting enough
sampling (or at least around the same amount.)  If your factor is low
and you get a lot of photons, the max interval setting is going to put a
limit on how many are actually deposited, while the global spacing might
be high enough to get enough photons even with a high factor.
You might be able to see some more dramatic difference if you increase
your global spacing and the max intervals of the media.
Another thing that may well be a factor is that you are using the
default samples of 1 for your media, which is likely too low.  You
should probably set intervals to 1 as well, as the default method is 3.
  Try adding something like:
   intervals 1
   samples 20
to your media block.
The problem I've been dealing with is that I have a mesh with scattering
media, and there is a thin section which is way too dark.  I've found
that increasing the max intervals and decreasing the factor has helped
to brighten the area, though I haven't found the right balance yet.  The
rest of the object looks just about the same regardless.  So, the upshot
is, I've found factor does do something, but it depends on circumstance,
and might require large adjustments to see a difference.  For example my
current setting:
   photons {
     spacing 0.005
     autostop 0
     media 300, 0.0025
helps but doesn't nearly help enough yet.  If its any help, this is the
media I've been using:
   media {
     method 3
     intervals 1
     samples 20
     absorption 1 - PaleGreen
     scattering { 4, 11 }
     aa_level 3
     aa_threshold 0.1
Lowering the aa_level from default 4 might speed things up for you as well.
-The Mildly Infamous Blue Herring
Date: 23 Aug 2008 01:45:00
Message: <web.48afa3b3cb097bd678dcad930@news.povray.org>
Blue Herring <pov### [at] bherringcotsenet> wrote:
> Hello,
> trying to tune this very parameter....
Lots of good info here, and very clearly stated.  Thanks for sharing it!
Ken W.
