Magnatune: We Are Not Evil
  POV-Ray : Newsgroups : povray.advanced-users : non-CSG objects in water Server Time: 9 Jan 2009 02:42:00 GMT
  non-CSG objects in water (Message 1 to 9 of 9)
Subject: non-CSG objects in water
Date: 24 Feb 2008 17:45:00
Message: <web.47c1ac997cee97df23eca01f0@news.povray.org>
I'm trying to put non-CSG'able objects in water, and, with radiosity lighting,
they come out too dark.  I'm guessing this is because the water is in the same
space as the objects themselves.
Any ideas?
Thanks
Subject: Re: non-CSG objects in water
Date: 24 Feb 2008 18:32:21
Message: <47c1b835$1@news.povray.org>
JH napsal(a):
> Any ideas?
> Thanks
if you use conventional light sources you need to make it (from simlest
to slowest):
-shadowless
or
-cast fake caustics
or
-cast pohotons
or
-make the light source a small highly ambient sphere (and crank up the
count)
also remember that media doesn't gather radiosity samples.
the ultimate time-killer:
+a0.0 +am2 +r9
Johnny D
Date: 24 Feb 2008 18:45:00
Message: <web.47c1baafee5908c123eca01f0@news.povray.org>
Jan Dvorak <janndvorakk [at] centrumcz> wrote:
> JH napsal(a):
> > Any ideas?
> to slowest):
The scene works fine with conventional light sources.  The problem is
with radioisty.  Everything in the water comes out too dark.
Date: 24 Feb 2008 19:03:12
Message: <47c1bf70$1@news.povray.org>
JH nous apporta ses lumieres en ce 2008/02/24 13:42:
>> JH napsal(a):
>>> Any ideas?
>> to slowest):
When tou need to cross a transparent surface, it count as a recursion step. If
recursion_limit is set to 1, the radiosity sampling stop on the down face of
your water. Try increasing recursion_limit by 1 or 2.
You can't use a two pass technique and remove that surface as it's an active
surface.
Creationism: God made all shit.
Date: 24 Feb 2008 20:00:01
Message: <web.47c1ccbcee5908c123eca01f0@news.povray.org>
> >>> Any ideas?
> surface.
Aha.  The water is inside a glass, and recurion_limit was 2.  I'm
trying the scene at 4 now (because the render wasn't slow enough
before...!)
Thanks!
Date: 24 Feb 2008 21:16:19
Message: <47c1dea3@news.povray.org>
JH napsal(a):
>>>>> Any ideas?
>> surface.
> before...!)
> Thanks!
This means:
-water in
-glass out
-glass in
-surface
You know you've been raytracing too long when...
you ever saw a beautiful scenerey and regretted not to take your 6"
reflective ball and a digital camera, thinking "this would have been a
perfect light probe"
-Johnny D
Date: 24 Feb 2008 22:00:01
Message: <web.47c1e7d1ee5908c123eca01f0@news.povray.org>
> > before...!)
> > Thanks!
> This means:
> -water in
> -glass out
> -glass in
> -surface
You're saying 4 isn't enough?  Or too much?  Or just right?
Date: 25 Feb 2008 05:24:30
Message: <47c2510e@news.povray.org>
JH nous apporta ses lumieres en ce 2008/02/24 16:55:
>>> before...!)
>>> Thanks!
>> This means:
>> -water in
>> -glass out
>> -glass in
>> -surface
You may need to push it up to 5, if you need the radiosity to go trough the
glass and acount for whatever's on the other side.
If 4 give you acceptable results, then stay with that.
"Sure, everyone's in favor of saving Hitler's brain, but when you put it into
the body of a great white shark, suddenly you're a madman."
             --Futurama
Date: 25 Feb 2008 14:10:00
Message: <web.47c2cbe7ee5908c15bb729400@news.povray.org>
> >>> before...!)
This did the trick!  Thank you.  The darkness inside the water has
been nagging at me for days.
4 is enough.  I really just need the stuff inside the water not to be
dark.  Upping the recursion made the render much slower, but it was
worth it.
Again, thanks.
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
