![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
how to draw some random chains grafted on the surface? Thanks.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"zj905" <zj9### [at] hotmail com> wrote in message
news:web.4716a8faa1216bf14f7090800@news.povray.org...
I assume you mean a sort of heap on the floor or something like that.
I've seen some POV-Ray chain macros about, but a quick Google didn't lead me
to any of them.
If I were doing this from scratch I'd probably start by defining a spline,
using a sphere sweep to check that it defined a suitably random looking path
across the surface in question and building it up so that successive loops
didn't intersect each other.
Next I'd define a chain link (e.g. two half torii and two cylinders CSG'd
together) such that the centre of the metal at one end of the link is at the
origin with the link in a clearly defined orientation (e.g. standing upright
and aligned with the Z-axis).
To position each chain link you need to keep a record of where the current
link is on the spline. Retrieve the coordinates of a point further along the
spline by incrementing the spline value until the distance between the two
points equals the distance from the inner edge of one torus to the inner
edge of the other. This gives you the position of the next link. The
difference between the two coordinates gives you a vector representing the
'lateral' orientation of the current link. Now rotate the current link
(still at the origin) along its length so that it's between 30 degrees and
150 degrees off that of the previous link (you could use randomness or a
more gravity based algorithm), use Reorient_Trans to orient it to the
'lateral' orientation, then translate it to the current link position.
Now your new point becomes your current point and you repeat until you reach
the end of your chain.
Hope this helps.
Chris B.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks for your detailed help. I really appreciate that. Another reader also
mentioned spline method. http://www.geocities.com/ccolefax/spline/index.html
The question is: this method can build one random chain. If the surface were
grafted with hundreds or thousands of chains, how to do? Is there any random
function available to generate the spline path?
> to any of them.
> Hope this helps.
> Regards,
> Chris B.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:web.471935d2144555e34849a21c0@news.povray.org...
> also
> were
> random
Hundreds sounds a lot (thousands sound a lot more). Depending upon the
effect that you're trying to achieve and the resolution you're planning to
render in, you're unlikely to actually see most of them as distincts
links/chains, so you may want to consider simulating most of the chains,
with maybe 3 or 4 more 'authentic' ones in the foreground to give the
impression that you've done them all.
IMO, the shape of a coil of chain beyond a certain distance could be
simultated with a blob using a randomised ring of spherical components
scaled vertically to squash it down a bit. You could apply a speckled
semi-transparent texture to make it look like a vague heap of something.
At a middle distance you could use the same shape with a load of randomly
placed chain links sticking out the surface, so that people can see some
real links there.
Then, for a small number of chains that are close to the camera, I'd go for
randomised splines to give chains that you can see in detail.
You could write a macro to generate a randomised path. For a coil you can
use a while loop with the rand() function to adjust the distance from the
centre of the coil and the amount of rotation in each step. For each point
you identify on the circular sweep you can check back along the spline for
points that are within a certain distance in x and z, then take the existing
y value and add one chain width to raise the current position above the
coincident position.
If you want to track a length of chain across other coils of chains you
could build a CSG composite of the 'simulated' shapes and use the trace
function to find the height of the top surface at the x,z location you wish
to use in your spline.
Chris B.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
