POV-Ray : Newsgroups : povray.advanced-users : Isosurface issue? Server Time
14 Mar 2026 19:52:12 EDT (-0400)
  Isosurface issue? (Message 1 to 7 of 7)
Subject: Isosurface issue?
Date: 14 Oct 2007 22:55:00
Message: <web.4712d57b4c6a1def30d4452f0@news.povray.org>
I was testing out some of the Isosurfaces from the documentation and came
across some thing which I'm not sure if its a bug, a limitation, or so I'm
just not doing it right.
The code below renders to the attached image. There seems to be some weird
normals, shading, or with the general shape. But if I change the viewing
coordinates to something else like <3,2,5> everything looks fine.
Can anybody tell me what I'm doing wrong or make any suggestions?
Image at <web.4712c21a4144865430d4452f0@news.povray.org>
 location <2,2,2>
 look_at <0,0,0>
isosurface{
        function{ abs(x)+abs(y)-1}
        contained_by {box{-1,1}}
        pigment{color White}
light_source {
 <2,2,2>
 color White
Subject: Re: Isosurface issue?
Date: 15 Oct 2007 02:35:00
Message: <web.471309f58e5bb9e1fddaa4670@news.povray.org>
> isosurface{
You have coincident surfaces of the object and its container.
The object would be an infinite bar, something like a
  box {<-1,-1,-infinity> <1,1,infinity>}
Changing the contained_by to
  contained_by {box <-2,-2,-1> <2,2,1>}
should do the trick.
Date: 15 Oct 2007 07:55:01
Message: <web.471354cd8e5bb9e194e61a50@news.povray.org>
Yeah, I tried changing it and it doesn't seem to do much good.
Date: 15 Oct 2007 11:05:01
Message: <web.4713809e8e5bb9e1fddaa4670@news.povray.org>
> > isosurface{
Err, sorry. That's wrong. At least, there is a
  scale sqrt(0.5)  rotate 45*z
missing. So, no, it is not a problem of coincident surfaces.
But then, the length of the gradient is sqrt(2) everywhere.
Maybe it is just a matter of increasing max_gradient to 1.5.
Date: 16 Oct 2007 04:11:32
Message: <47147234$1@news.povray.org>
> camera {
>  location <2,2,2>
>  look_at <0,0,0>
> isosurface{
> light_source {
>  <2,2,2>
>  color White
Woody, I received your bug report to the povray.bugreports group, however
this is *not* a bug.  The messages output by POV-Ray at the time of
rendering should provide the clue:
"Shutdown Warning: The maximum gradient found was 1.375, but the
max_gradient of the isosurface was set to 1.100.  The isosurface may
contain holes!  Adjust max_gradient to get a proper rendering of the
isosurface."
Therefore, to resolve the issue you're seeing (and as Mark also noticed)
you have to include a higher max_gradient value in your isosurface, which
can be done as follows:
isosurface{
   max_gradient 1.375
I'd recommend checking the isosurfaces area in the documentation to read
more about max_gradient and why this happens as it's something that needs
to be watched out for.  Note that the higher the max_gradient setting is,
the slower the isosurface takes to render, which is why the default value
of max_gradient is set so low.
As an aside, please ensure in the future when submitting possible bugs to
the povray.bugreports group that you check that the provided SDL is
syntactically correct, as the SDL you sent with your post contained a
syntax error that made it difficult to determine whether the problem you
were having was with the syntax or with something else.
Kind regards,
Lance Birch.
thezone - thezone.firewave.com.au
Date: 16 Oct 2007 11:41:27
Message: <4714dba7$1@news.povray.org>
Lance Birch nous apporta ses lumieres en ce 2007/10/16 04:11:
>> I'm
>> weird
>> camera {
>>  location <2,2,2>
>>  look_at <0,0,0>
>> isosurface{
>> light_source {
>>  <2,2,2>
>>  color White
> however this is *not* a bug.  The messages output by POV-Ray at the time
> of rendering should provide the clue:
> isosurface."
> which can be done as follows:
> isosurface{
>   max_gradient 1.375
> needs to be watched out for.  Note that the higher the max_gradient
> setting is, the slower the isosurface takes to render, which is why the
> default value of max_gradient is set so low.
> to the povray.bugreports group that you check that the provided SDL is
> Kind regards,
> Lance Birch.
A hi max_gradient don't always mean slow render, and a small gradient don't
equate to fast render. A gradient of 1.4 is not large, and in this case, setting
max_gradient to 1.3 should be enough.
If your function have area of small gradient (close to 1 or less close to the
tresshold) and area of large gradient (over 1000), THEN you get slow rendering,
as the low gradient areas get hugely oversampled. A possible solution for that
can be to use the log of the function as it could compress the hi gradient areas.
WARNING: The consumption of alcohol may cause you to tell your friends over and
over again that you love them.
Date: 16 Oct 2007 22:18:20
Message: <471570ec$1@news.povray.org>
>>> came
>>> so I'm
>>> weird
>>> camera {
>>>  location <2,2,2>
>>>  look_at <0,0,0>
>>> isosurface{
>>> light_source {
>>>  <2,2,2>
>>>  color White
>> time of rendering should provide the clue:
>> isosurface."
>> noticed) you have to include a higher max_gradient value in your
>> isosurface, which can be done as follows:
>> isosurface{
>>   max_gradient 1.375
>> read more about max_gradient and why this happens as it's something
>> that needs to be watched out for.  Note that the higher the
>> max_gradient setting is, the slower the isosurface takes to render,
>> which is why the default value of max_gradient is set so low.
>> you were having was with the syntax or with something else.
>> Kind regards,
>> Lance Birch.
> don't equate to fast render. A gradient of 1.4 is not large, and in this
> case, setting max_gradient to 1.3 should be enough.
> to the tresshold) and area of large gradient (over 1000), THEN you get
> slow rendering, as the low gradient areas get hugely oversampled. A
> possible solution for that can be to use the log of the function as it
Hi Alain, that's correct.  I was simply noting that the reason POV-Ray
uses a low max_gradient *by default* is that a *higher than required*
max_gradient results in more samples and a slower render.  I noted this in
case Woody wondered why the default value of max_gradient was so low,
since he submitted a bug report about his problem.
Lance.
