For any number of points n, (n>3 if that makes it any easier), what is the
simplest spline that defines a circle (value of spline at 0= start of
circle, 1= back to same point).
I have this fear that what I think may be a simple solution would instead be
a rounded square for n=4.
The simple answer is that you can not make a perfect circle with
splines, because sin() and cos() have an infinite Taylor expansion.
The more elaborate answer is that you can get a reasonable approximation
with 4 cubic splines. With more splines the approximation can be even
better. With two it is not even close.
You want to know how to define it in one spline, that I don't know. ;)
The 'problem' with standard splines is that not all points are treated
the same. Often the first and last point are on the spline whereas the
others are control points, indicating where 'approximately' you want the
spline to go. I wouldn't be surprised if there is a set of base
functions that are totally symmetrical and can be used for circular
splines, but POV does not support them (AFAIK).
If this question is beyond POV, I might look into the literature for you
and/or try to find a reasonable solution by minimizing some distance
function, but I would advise you to build a circle with a set of simple
splines (or use a very low cylinder).
For any number of points? Does that mean you know how many sample points
will be taken? Also what do you mean by 'simple?' If you create a control
point for each and every expected sample point, then shouldn't it be as
'perfect' as can be? I'd just create a while loop going (either directly
or in effect) from -1/n to n + (1/n) along with your
Scale*sin(Position*2*pi) and Scale*cos(Position*2*pi) functions to create a
cubic_spline.
Charles
> be
About n=11, or 45 degrees apart, remember you need one before
and one after as control points usually. You can set a macro up that
will evaluate a circle though, it's one line of code.
Demo scene....
#version 3.6;
global_settings {assumed_gamma 1.0} default{finish{ambient 1}}
camera {location <0,0,-4>
direction 1.5*z
look_at <0,0,0>}
#declare rad = 1.25;
#declare circleS = spline {
natural_spline
-0.125,vrotate(<0,rad,0>,<0,0,-45>)
0.0, vrotate(<0,rad,0>,<0,0, 0>)
0.125,vrotate(<0,rad,0>,<0,0, 45>)
0.25, vrotate(<0,rad,0>,<0,0, 90>)
0.375,vrotate(<0,rad,0>,<0,0,135>)
0.5, vrotate(<0,rad,0>,<0,0,180>)
0.625,vrotate(<0,rad,0>,<0,0,225>)
0.75, vrotate(<0,rad,0>,<0,0,270>)
0.875,vrotate(<0,rad,0>,<0,0,315>)
1.0, vrotate(<0,rad,0>,<0,0, 0>)
1.125,vrotate(<0,rad,0>,<0,0, 45>)
#macro circleM(a) vrotate(<0,rad,0>,<0,0,360*a>) #end
#local c = 0;
#while (c<=1)
sphere {circleS(c),0.02 pigment{rgb <1,0,0>}translate<0,0,-0.03>}
sphere {circleM(c),0.04 pigment{rgb <0,1,0>}}
#local c=c+0.01;
cylinder {<0,0,0>,<0,0,0.1>,rad pigment{rgb <0,0,1>}}
Subject: Re: Describing a perfect circle with a spline.
Date: 25 Sep 2007 10:26:08
Message: <46f91a80@news.povray.org>
gregjohn nous apporta ses lumieres en ce 2007/09/24 13:55:
What do you want to do exactly, and how is it suposed to look?
If it's suposed to look as a dougnut, then you should use a torus: MUCH simpler.
torus{Major_Radius, Minor_Radius rotate Your_Rotation translate Your_Translation}
If it's suposed to like a thick disk, then you could go with a cylinder.
cylinder{Top_Face, Bottom_Face, Radius}
If it suposed to look like a disc, there is the disc primitive.
disc{Center, Normal, Radius [,Hole_Radius]}
If you want a thick disk with rounded edges, you can use an union of a cylinder
and a torus.
union{cylinder{Top, Bottom, Radius}torus{Major_Radius, Minor_Radius}rotate
Some_Rotation translate Some_Translation}
cylinder and disc can be deffined at any arbitrary location.
torus are initialy centered at the origin, on the x-z plane around the y axis.
All of those will give you a perfectly circular shape and can be scaled if needed.
For here we are not afraid to follow truth wherever it may lead.
Thomas Jefferson
Alain <ele### [at] netscape net> wrote:
> What do you want to do exactly, and how is it supposed to look?
I wanted a spline My_Spline where My_Spline(n) spits out 3D points on a
circle for any n, if 0<n<1, and with any predefined
Number_of_Entries_in_Spline.
I knew a way to code this which seemed a PITA, and I feared it were neither
necessary nor sufficient. The advice I got above seems to confirm that it
is necessary and sufficient.
thanks all.
I guess that this remark is aimed at my first statement that it is
essentially not possible. To (hopefully) clarify a bit more: splines are
polynomials and sin() and cos() require a polynomial with infinite
length to describe. So you can approximate a circle but never get is
*exactly* right. That does not mean that for all practical purposes your
solution below might give a sufficient approximation. You may even tweak
the Scale a bit, because now all points on the curve are inside the
circle. Increasing it a bit so that some of the curve is inside and
another part is outside decreases the error even more.
> cubic_spline.
True. There's always the fact that we're using floats with a finite number
of bits. I figure <2*pi*cos(Value),2*pi*sin(Value),0> is probably as close
to definition as we can express. My thinking was just that maybe he could
elminate the added aproximation that comes with using a spline by
retrieving points from the spline that happen to be the very same points
that defined the spline.
Charles
I was under the impression that you could make a perfect circle with
rational b-splines (
http://www.cl.cam.ac.uk/teaching/2000/AGraphHCI/SMEG/node5.html ). These
work around the problem in some way because they're not just a simple
polynomial. POV-Ray doesn't support these so it's not useful here.
My question would be, why bother making a spline in the shape of a circle,
when you already know the <cos(theta),sin(theta),0> method? You can just use
that in place of your spline.
- Slime
[ http://www.slimeland.com/ ]
http://news.povray.org/povray.binaries.animations/thread/%3C46f9ba61%40news.povray.org%3E/
Because then I can make a skinnable mesh2 macro where I can change from
cross-section to cross-section between circles and square-shaped contours.
