POV-Ray : Newsgroups : povray.advanced-users : Spiralled object with a decreasing radius Server Time
28 Sep 2024 14:19:09 EDT (-0400)
  Spiralled object with a decreasing radius (Message 1 to 4 of 4)
Subject: Spiralled object with a decreasing radius
Date: 23 Apr 2007 19:50:01
Message: <web.462d4452550713307a0e9df90@news.povray.org>
I would first like to thank Julius Klatte for posting some spiral tutorials
on his website (http://members.tripod.com/~klatte/pov/helix.html).  All
credit for the following information belongs to him.
His basic tutorial is as follows:
camera { location <0,2,-10> look_at <0,0,0> }
light_source { <-30,40,-50> rgb 1 }
light_source { <60,20,-30> rgb 1 }
#declare Tex = texture { pigment { color rgb <0.95,0.65,0.55> } finish {
phong 1 phong_size 100 } }
#declare S = sphere { 0, 0.25 texture { Tex } }
#declare Precision = 0.5;
union {
  #declare T = 0;
  #while (T<360)
    object { S translate <0,T/180,-2> rotate 4*y*T }
    #local T = T + 1/Precision;
rotate x*-20 }
Now, my question is, "Is there is any way to cause each subsequent sphere to
have a smaller or larger diameter than the one before it?"
Unfortunately, I'm only just dabbling with macro's and such and I'm not all
that good at it.  I can understand this macro only because Julius Klatte
explains it very well and "breaking it down" backwards isn't that hard for
me.  However, trying to create my own macro, even using his as a guide, is
a bit beyond me at the moment.  I appreciate any help that anyone can offer
on this, especially if it is in the form of a macro that I can copy and
paste into my POV file!  Thanks!
Take care and have a great day....
ciao,
john.
Subject: Re: Spiralled object with a decreasing radius
Date: 23 Apr 2007 20:25:01
Message: <web.462d4c272acc8fd8b160ffde0@news.povray.org>
> union {
>   #declare T = 0;
>   #while (T<360)
>   #end
> rotate x*-20 }
> ciao,
> john.
Yes.  Right now you're translating it using the changing variable T.  All
you need to do is also scale it by something that changes with T.  Just
make sure you scale before you translate or the scale will affect the
position of the sphere as well.   E.g:
>     object { S scale 1.5-T/360 translate <0,T/180,-2> rotate 4*y*T }
or whatever numbers look good.
Charles
Date: 23 Apr 2007 21:05:02
Message: <web.462d57a72acc8fd87a0e9df90@news.povray.org>
> > union {
> >   #declare T = 0;
> >   #while (T<360)
> >   #end
> > rotate x*-20 }
> > ciao,
> > john.
> Charles
Woot!
Thanks, Charles!  I was messing around with scale, but I just didn't know
the correct formula for it.  Thanks again!
ciao,
john.
Date: 24 Apr 2007 08:05:02
Message: <web.462df15c2acc8fd8fddaa4670@news.povray.org>
> union {
>   #declare T = 0;
>   #while (T<360)
>   #end
> rotate x*-20 }
Replace the "#declare S" and "object" lines by
  #macro S(T) = sphere {0, (something that depends on T) texture {Tex}}
  object {S(T) translate <0,T/180,-2> rotate 4*y*T}
On a side note you may want to look into the sphere_sweep object. That one
can help you reduce Precision while improving accuracy.
Best regards,
  Mark Weyer
