POV-Ray : Newsgroups : povray.advanced-users : jitter with antialiasing turned off Server Time
18 Nov 2025 09:51:42 EST (-0500)
  jitter with antialiasing turned off (Message 1 to 7 of 7)
Subject: jitter with antialiasing turned off
Date: 18 Mar 2007 23:55:01
Message: <web.45fe16d78d4a86e8add0a3280@news.povray.org>
Hi again,
It would appear from the online doc
(http://www.povray.org/documentation/view/3.6.1/223/) that jittering is not
used when antialiasing is turned off: "If anti-aliasing is not used one
sample per pixel is taken regardless of the super-sampling method
specified."
Is this a correct interpretation of the text?
Are there any random sampling algorithms used when antialiasing is turned
off?
cheers
Subject: Re: jitter with antialiasing turned off
Date: 19 Mar 2007 02:56:48
Message: <45fe4240$1@news.povray.org>
dragonmage wrote:
> Hi again,
> specified."
I don't believe so; rather, that single ray should be randomly perturbed
due to the jitter.
...Chambers
Date: 19 Mar 2007 04:14:56
Message: <45fe548f@news.povray.org>
> specified."
> off?
  Just to make sure that you don't have a confusion about this:
Antialiasing jittering is only done inside a pixel for the extra rays
for the antialiasing. It's not randomized raytracing as in "send rays
in random directions".
  If you randomize the rays more than a pixel, you'll just get a noisy
image (in fact, even if you randomize inside a pixel but without antialising
you will also get noise).
  You can actually simulate what it looks like by adding something like
this at the end of your camera definition block:
normal { bumps .01 scale 1e-5 }
Date: 19 Mar 2007 21:25:02
Message: <web.45ff44e8caa49936691a5d0@news.povray.org>
> > specified."
> > off?
ok, so jitter won't "move" a pixel but may change its rendered colour?
I have "    jitter 0" in the global settings, photons anyway so, according
to the manual there will be no jitter subsampling.
thanks
Date: 20 Mar 2007 14:13:35
Message: <4600325f@news.povray.org>
> off?
Pragmatically, try rendering your scene twice and flip between the
two renders in your favorite viewer. Even a slightly changed pixel
will attract your attention due to the way human vision works ;)
Date: 20 Mar 2007 18:32:26
Message: <46006f0a$1@news.povray.org>
dragonmage nous apporta ses lumieres en ce 19-03-2007 22:20:
>>> specified."
>>> off?
>>                                                           - Warp
> thanks
There will be no jittering in the subsampling. All subsamples will be taken in a
nice, regular array of points.
I'm interested in the fact that the less secure a man is, the more likely he is
to have extreme prejudice. (Clint Eastwood)
Date: 20 Mar 2007 23:00:02
Message: <web.4600ada7caa499add0a3280@news.povray.org>
> >>                                                           - Warp
> > thanks
ok, thanks,
that at least explains how jittering works - I'll see if the programming ppl
can point me at the code that does it,
chris
> Alain
