POV-Ray : Newsgroups : povray.advanced-users : volume calculations Server Time
2 Apr 2026 03:10:18 EDT (-0400)
  volume calculations (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: volume calculations
Date: 10 Jan 2007 12:22:01
Message: <45a520b9$1@news.povray.org>
Warp wrote:
> Tim Attwood <tim### [at] comcastnet> wrote:
>> Using extents of an object you can calculate the
>> volume of the bounding box, then use a large number of
>> random point samples within the bounding box to determine
>> the percent of samples that are inside the object, then
>> the volume can be estimated to be that percent of the
>> bounding volume.
>  If you want any accuracy at all, it would take a very LONG time.
>  I would estimate that getting one additional decimal of accuracy
> (or whichever base is used) requires O(n^3) more points to be sampled.
> You can figure out that that number grows quite fast.
For objects that fill a reasonably high percentage of the bounding box (such
as a sphere) it wouldn't be a big problem unless you really care about high
accuracy. For other objects though, such as, say, a cylinder from <-1,-1,-1>
to <1,1,1> with radius 0.01, testing all points (with some proximity) within
the bounding box is extremely inefficient. However, pre-testing with trace
lines within the bounding box parallel with one or more axes could be used
to weed out by far the most points beforehand, and this would only be
O(n^2).
Rune
http://runevision.com
Date: 10 Jan 2007 12:33:24
Message: <45a52364$1@news.povray.org>
> box (such as a sphere) it wouldn't be a big problem unless you really
> care about high accuracy. For other objects though, such as, say, a
> cylinder from <-1,-1,-1> to <1,1,1> with radius 0.01, testing all
> points (with some proximity) within the bounding box is extremely
> inefficient. However, pre-testing with trace lines within the
> bounding box parallel with one or more axes could be used to weed out
> by far the most points beforehand, and this would only be O(n^2).
...in most common cases that is. It won't work for, say, a sphere with a
slightly smaller sphere carved out of it.
Come to think of it, the tracing could be used iteratively to do the volume
calculation in the first place. This would work in all cases and would only
be O(n^2*m) where m represents the complexity of the object.
Rune
Date: 10 Jan 2007 13:20:51
Message: <45a52e83$1@news.povray.org>
Tim Attwood wrote:
>> Is there a way to calculate and/or export the internal volumes of the
>> finite
>> CSG objects in a POV-Ray scene?
> bounding volume. This is sort of like filling a real object
> with water then measuring the water.
A better way to sample the volume (although requiring external
processing) may be to render a series of slices of the object and then
sum the number of covered pixels in those images. This can be done using
an object pattern mapped to a plane and animating the translation of the
pattern along the axis perpendicular to the plane, much like a CAT-scan
really.
Daniel Nilsson
going back to lurking mode...
Date: 10 Jan 2007 14:00:59
Message: <45a537eb$1@news.povray.org>
Daniel Nilsson wrote:
>>> the finite
> using an object pattern mapped to a plane and animating the
> translation of the pattern along the axis perpendicular to the plane,
> much like a CAT-scan really.
This would require exactly the same amount of insideness tests as the
suggestion by Tim Attwood; only they would be done during rendering instead
of during parsing.
Rune
Date: 10 Jan 2007 16:55:31
Message: <45a560d3$1@news.povray.org>
> of during parsing.
Yes, that is true. But povray's built-in adaptive anti-aliasing will
save some samples. Implementing adaptive sampling in SDL is probably not
as fast.
Anyway, I don't think this is what the OP was looking for.
Daniel Nilsson
haven't really used povray for several years, still lurking here though
Date: 10 Jan 2007 17:50:38
Message: <45a56dbe$1@news.povray.org>
Rune nous apporta ses lumieres en ce 10-01-2007 12:33:
> Rune
What about a complex shape with another complex shape carved out of it, making a
strange, one opening, hole?
Age is a very high price to pay for maturity.
Date: 11 Jan 2007 05:57:20
Message: <45a61810$1@news.povray.org>
I ran a test on a half sphere that came out in 13 seconds
with an accuracy of about 0.3%
The half sphere should be 2/3 pi r cubed volume, 2.094
since I used a r of 1, and the estimate was 2.087
I ran a second test with the half sphere scaled up by 100
and got the same sort of result 13 seconds and 2087920,
so the adaptive loop in my volume estimate algorithm isn't
sensitive to object size.
I did a third test with a narrow cylinder (rotated so that the
bounding was larger), it was off by about 1.3% in 11 seconds.
If I remember my statistics right, it only takes a fixed number
of samples to accurately represent a larger population to
some confidence level, which is why you see the plus or minus
4% on a lot of news polls. So it should run about O(n) time, though
that time increases O(n^3) as you modify the algorithm to be more
accurate.
I could see that a narrow enough object might return
zero volume if the real volume is only a few percent of the
bounding box.
Date: 12 Jan 2007 09:45:01
Message: <web.45a79e97174c9403fddaa4670@news.povray.org>
> Is there a way to calculate and/or export the internal volumes of the finite
Might be the same that Rune mentioned:
If you make the surface transparent and fill the interior with a uniformly
emitting medium, then the sum over the pixels of an orthographic rendering
should give you a reasonable approximation of the volume.
  Mark Weyer
Date: 12 Jan 2007 12:49:37
Message: <45a7ca31@news.povray.org>
  How can a 2-dimensional projection of a 3-dimensional object give you
the volume of the object?
Date: 12 Jan 2007 14:05:45
Message: <45a7dc09$1@news.povray.org>
>> uniformly emitting medium, then the sum over the pixels of an
>> orthographic rendering should give you a reasonable approximation of
>> the volume.
Because each pixel's color represents the volume of the object contained
within the confines of the area of the object that is behind that pixel? The
volume-to-color mapping is non-linear though, so one would have to know or
test the mapping used, but that should be quite simple.
Rune
