POV-Ray : Newsgroups : povray.advanced-users : Use Slope pattern for Planting distribution? Server Time
31 Mar 2026 03:39:41 EDT (-0400)
  Use Slope pattern for Planting distribution? (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Use Slope pattern for Planting distribution?
Date: 12 Dec 2006 16:44:21
Message: <457f22b5$1@news.povray.org>
>>   Some basic vector math knowledge could be of great help when designing
>> thing with POV-Ray... :P
> In my defence, I am relatively new and to me, a "vector" is a *direction*
> (which could be defined in various ways).  Yet what is returned is
> obviously three float values combined in what POV calls a "vector".
> Therefore, the normal vector could define a point 1 unit (or more?) away
> from the intersected point in the perpendicular direction, or could be
> that
> point minus the intersected point.  So I suppose my real question is: How
> exactly does POV define its vectors?
In POV vectors are directions from the origin. This can be used to represent
a point <x,y,z> by the magnitude of the vector, or in some cases the
magnitude
is ignored and the vector only represents a direction. For example, the
normal
returned from the trace function represents the direction of the vector
perpendicular
to the surface as a unit vector from the origin. (A unit vector has a length
of 1 unit)
The vnormalize function returns a unit vector from a non-unit vector by
changing the
vector length to one without changing the direction. Essentially, POV uses
vectors
to represent points, because points ARE vectors, but uses unit vectors for
directions.
To complicate matters a bit more, POV also uses vectors to define colors, so
there
are options for two more vector components filter and transmit, making a 5D
vector.
For clarity of use the dot x, dot y, and dot z accessors can be used as dot
red,
dot green, and dot blue; so N.x = N.red, N.y = N.green, and N.z = N.blue.
The other 2 components can be accessed with dot filter, and dot transmit.
Addtionally you can use dot u and dot v for 2D vectors. So N.x = N.u, and
N.y = N.v. Also 4D vectors <x,y,z,t>, where N.t = N.filter.
Date: 12 Dec 2006 16:53:25
Message: <457f24d5@news.povray.org>
Kirk Andrews nous apporta ses lumieres en ce 12-12-2006 12:23:
> Thank you, that was very helpful--
> from the intersected point in the perpendicular direction, or could be that
> In any case, you've certainly answered my current problem and I appreciate
> your patience with my ignorance.
> Kirk
In fact, a vertor is a direction PLUS a distance. It can be defined as 3 angles
and a distance, OR as the end point's coordinates relative to it's starting point.
In 2D, it's an angle plus a lenght or the 2D coordinates of the tip relative to
the start.
A normalised vector is a vector witch is 1 unit in lenght. Normaly, the normal
vector returned by the trace function is such a vector.
Make yourself a better person and know who you are before you try and know
someone else and expect them to know you.
Date: 12 Dec 2006 17:04:16
Message: <457f2760$1@news.povray.org>
Technically, it's a direction PLUS a distance that's invariant under
rotation or translation of the coordinate system in which it's embedded.
:-) Otherwise, it's just a tuple.
     Scruffitarianism - Where T-shirt, jeans,
     and a three-day beard are "Sunday Best."
Date: 13 Dec 2006 02:54:05
Message: <457fb19d$1@news.povray.org>
"Kirk Andrews" <kir### [at] hotmailcom> schreef in bericht
news:web.457eb359aa33b1599033e1160@news.povray.org...
> I'm trying to use the trace command to plant grass on my Isosurface
> landscape, but I don't want it to "grow" on steep grades.  Is it possible
> to use the slope pattern to control my distribution, or is there another
> way to do this?
All the answers given so far are excellent, however, I think you need an
example scene now to understand it fully (I did).
I shall post one today in p.b.s-f under the same header.
Date: 13 Dec 2006 03:05:32
Message: <457fb44c$1@news.povray.org>
In fact, It is such a small piece of code, that I can post it here below.
// -------- Placing the trees -------------
#debug "Placing trees...\n"
#declare Spacing = 1;
#declare Cnt = 0;
#declare PosX = -15;
#while (PosX < 15)
  #declare PosZ = -25;
  #while (PosZ < 15)
    // trace function
    #declare Norm = <0, 0, 0>;
    #declare Start = <PosX+(rand(Seed)-0.5)*Spacing,
UpperBound+Isoscale.y+1, PosZ+(rand(Seed2)-0.5)*Spacing>;
    #declare Pos = trace (
                          Landscape,       // object to test
                          Start,           // starting point
                          -y,              // direction
                          Norm );          // normal
    #if (Norm.x != 0 | Norm.y != 0 | Norm.z != 0)   // if intersection is
found, normal differs from 0
      #if ((vdot(Norm, y)>0.5) & (Pos.y < 5.5))     // criteria for placing
trees: not too steep and not too high
        object {
          //Tree (0.5+rand(Seed)*0.02)
          TREE
          scale RRand(1.0, 2.5, Seed)
          rotate RRand(0, 360, Seed2)*y
          translate Pos
        #declare Cnt = Cnt+1;
    #declare PosZ = PosZ+Spacing;
  #declare PosX = PosX+Spacing;
#debug concat("Placed ", str(Cnt,0,0), " Trees\n")
Date: 13 Dec 2006 04:34:29
Message: <457fc925@news.povray.org>
  Btw, another way of testing that is:
  #if(vlength(Norm) > 0)
  Does trace() always return a normalized vector?
Date: 13 Dec 2006 07:20:39
Message: <457ff017$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schreef in bericht
news:457fc925@news.povray.org...
Ah, yes! that's neat!
Yes, if you define also the fourth trace parameter (a vector), Norm in this
case (see documentation 3.2.1.4.5). This works fine as far as I can tell. To
tell the truth, I used this after an example from somebody else :-)  So,
things are transmitted on. However, there might be an even better way to do
this, but I have not investigated that far as this worked for me.
Date: 13 Dec 2006 16:38:12
Message: <458072c4@news.povray.org>
  There's no such section number in the current documentation
(http://povray.org/documentation/view/3.6.1/570/)
  As for the documentation on the trace() function (2.2.1.4.5), it does not
mention returning a normalized vector.
Date: 14 Dec 2006 04:03:35
Message: <45811367@news.povray.org>
news:458072c4@news.povray.org...
>> this
Strange....
My documentation for version 3.6 is headed:   3.2.1.4.5  Functions
This is what it says about trace():
quote
trace(OBJECT_IDENTIFIER, A, B, [VECTOR_IDENTIFIER]). trace helps you finding
the exact location of a ray intersecting with an object's surface. It traces
a ray beginning at the point A in the direction specified by the vector B.
If the ray hits the specified object, this function returns the coordinate
where the ray intersected the object. If not, it returns <0,0,0>. If a
fourth parameter in the form of a vector identifier is provided, the normal
of the object at the intersection point (not including any normal
perturbations due to textures) is stored into that vector. If no
intersection was found, the normal vector is reset to <0,0,0>.
Note: Checking the normal vector for <0,0,0> is the only reliable way to
determine whether an intersection has actually occurred, intersections can
and do occur anywhere, including at <0,0,0>.
unquote
so.... what do you think?
Date: 14 Dec 2006 05:52:06
Message: <45812cd6$1@news.povray.org>
Thomas de Groot nous apporta ses lumieres en ce 14-12-2006 04:03:
>>> this
> Strange....
> quote
> unquote
> Thomas
There is no mention of a normalised normal vector, it mention the normal vector.
A day for firm decisions!!!!!  Or is it?
