POV-Ray : Newsgroups : povray.advanced-users : Use Slope pattern for Planting distribution? Server Time
31 Mar 2026 00:16:03 EDT (-0400)
  Use Slope pattern for Planting distribution? (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Use Slope pattern for Planting distribution?
Date: 13 Dec 2006 04:34:29
Message: <457fc925@news.povray.org>
Thomas de Groot <t.d### [at] internldotnet> wrote:
>     #if (Norm.x != 0 | Norm.y != 0 | Norm.z != 0)
  Btw, another way of testing that is:
  #if(vlength(Norm) > 0)
>       #if ((vdot(Norm, y)>0.5) & (Pos.y < 5.5))
  Does trace() always return a normalized vector?
Date: 13 Dec 2006 07:20:39
Message: <457ff017$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schreef in bericht
news:457fc925@news.povray.org...
Ah, yes! that's neat!
Yes, if you define also the fourth trace parameter (a vector), Norm in this
case (see documentation 3.2.1.4.5). This works fine as far as I can tell. To
tell the truth, I used this after an example from somebody else :-)  So,
things are transmitted on. However, there might be an even better way to do
this, but I have not investigated that far as this worked for me.
Date: 13 Dec 2006 16:38:12
Message: <458072c4@news.povray.org>
  There's no such section number in the current documentation
(http://povray.org/documentation/view/3.6.1/570/)
  As for the documentation on the trace() function (2.2.1.4.5), it does not
mention returning a normalized vector.
Date: 14 Dec 2006 04:03:35
Message: <45811367@news.povray.org>
news:458072c4@news.povray.org...
>> this
Strange....
My documentation for version 3.6 is headed:   3.2.1.4.5  Functions
This is what it says about trace():
quote
trace(OBJECT_IDENTIFIER, A, B, [VECTOR_IDENTIFIER]). trace helps you finding
the exact location of a ray intersecting with an object's surface. It traces
a ray beginning at the point A in the direction specified by the vector B.
If the ray hits the specified object, this function returns the coordinate
where the ray intersected the object. If not, it returns <0,0,0>. If a
fourth parameter in the form of a vector identifier is provided, the normal
of the object at the intersection point (not including any normal
perturbations due to textures) is stored into that vector. If no
intersection was found, the normal vector is reset to <0,0,0>.
Note: Checking the normal vector for <0,0,0> is the only reliable way to
determine whether an intersection has actually occurred, intersections can
and do occur anywhere, including at <0,0,0>.
unquote
so.... what do you think?
Date: 14 Dec 2006 05:52:06
Message: <45812cd6$1@news.povray.org>
Thomas de Groot nous apporta ses lumieres en ce 14-12-2006 04:03:
>>> this
> Strange....
> quote
> unquote
> Thomas
There is no mention of a normalised normal vector, it mention the normal vector.
A day for firm decisions!!!!!  Or is it?
Date: 14 Dec 2006 07:01:26
Message: <45813d16@news.povray.org>
  Yes, there's no mention of the returned vector being normalized. Thus
it may not be wise to assume it is, and thus it would be wise to use
vnormalize(), just in case.
Date: 14 Dec 2006 09:16:58
Message: <45815cda@news.povray.org>
news:45813d16@news.povray.org...
OK. There is something that I am missing here obviously. When you mention
normalize, I think normal. To tell the truth, I have never thought about the
difference, and as things work perfectly well (in the case of trace to plant
my trees) I never thought further. However, I wonder about the difference. I
read the docs, but except for hardly two lines of text, I find no mention of
what the importance of vnormalize() is and what it is supposed to do. Could
you please explain?
Date: 14 Dec 2006 12:26:45
Message: <45818955@news.povray.org>
Just ran a test with the Makesnow macro and it looks to be normalized indeed
(all vlength(Norm)=1). It's just not documented probably.
G.
Date: 14 Dec 2006 14:26:55
Message: <4581a57f@news.povray.org>
> difference
  Despite the similarity in the names of the terms, a normal vector and a
normalized vector talk about two different things:
  - A normal vector is a vector perpendicular to a surface (or line in 2D)
at a certain point.
  - A normalized vector is a vector of length 1.
  Thus a normalized normal vector is a normal vector of length 1.
  The dot product returns values between 0 and 1 only if the two vectors
are normalized.
  (More specifically, the dot product is the product of the lengths of
the two vectors and the cosine of the angle between them. Naturally if
both lengths are 1, the result is just the cosine.)
Date: 15 Dec 2006 02:57:35
Message: <4582556f@news.povray.org>
news:4581a57f@news.povray.org...
> at a certain point.
> are normalized.
Thanks Warp! This makes it clear for me. Perhaps it would be a suggestion to
add something like this in the documentation? I think that would be useful.
