POV-Ray : Newsgroups : povray.advanced-users : the POV-ray SDL--similar to Java and/or Python? Server Time
26 Mar 2026 05:23:09 EDT (-0400)
  the POV-ray SDL--similar to Java and/or Python? (Message 40 to 49 of 79)
Subject: Re: the POV-ray SDL--similar to Java and/or Python?
Date: 13 Sep 2006 19:04:54
Message: <45088e96$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>>Not necessarily. They're pointed to by the object that represents the
>>list as a whole. What pointer would you drop to make the list
>>garbage-collect with a reference-count GC?
>   How do languages where there no concept of "new" (as in Java or C++)
> nor a Java-style GC of dynamically allocated objects do it?
They don't dynamically allocate and deallocate memory, I guess. I'm not
sure what your questions means. What I'm saying is that having circular
links between objects is not at all uncommon in languages that allow
such. It's the natural way to represent many semi-independent entities
(like screens/windows, frames/scrollbars, RPG objects/rooms, tree nodes,
etc.).
Obviously, if you don't have dynamically-allocated objects, then you
don't have to worry about circular references with reference-counting
garbage collection. If you have dynamically-allocated objects *and* no
GC, then obviously it's up to the programmer to free things without
assistance, and programmed reference counting won't fix that.
>>Plus, reference counting has very bad performance as well as being
>>non-real-time and uninterruptable.
>   Very bad performance? I think that incrementing/decrementing a counter
> each time an object is copied doesn't increase too much of its slowness.
Not true. You have to also account for the object's reference count
overflowing, for example. Plus, you actually have to *free* the objects
when the counter goes to zero. Generational GC doesn't have to do
anything with objects that have been freed (which admittedly makes
finalizers messy, but they are messy to handle "correctly" in any
language and model). You can allocate 100,000 individual objects and
free them all with one instruction. There's a reason why nobody uses
reference-counted garbage collection for real any more.
     Just because you find out you are
     telepathic, don't let it go to your head.
Date: 13 Sep 2006 19:13:17
Message: <4508908d$1@news.povray.org>
Sorry, can't help responding to this: If your reference counter variable
size is the same as your native pointer size, it can *never* overflow.
	Thorsten
Date: 13 Sep 2006 19:27:56
Message: <450893fc$1@news.povray.org>
Yes, but that's very inefficient, especially if you have objects that
are persisted elsewhere (e.g., if you have objects distributed across
many computers, or stored in named files, or in an OO database). Most
reference-counted systems allocate between five and eight bits for
reference counts. Incidentally, that's another reason reference counting
isn't used much - the size penalty. And you still have to be able to do
mark-and-sweep to account for circular references anyway.
Date: 13 Sep 2006 19:28:43
Message: <4508942b@news.povray.org>
  It's impossible for a reference counter to overflow. You can't allocate
that much memory. You can't have pointers pointing to that many objects
in the first place.
  If you had to manage more data than the pointer size of the architecture
can point to, then everything handling the data will be bigger&slower
anyways. A reference counter won't matter much.
  Assuming no memory fragmentation, of course.
  Besides, a reference-counting system doesn't have to *free* the
objects immediately when the last reference dies. It can mark the
object as "to be freed" and put it somewhere to wait.
  Btw, how does the GC engine know that the object is not used anymore?
Date: 13 Sep 2006 19:42:40
Message: <45089770@news.povray.org>
  Oh, of course handling more data than the natural pointer size of the
system is very efficient. It's just the reference counter which is
inefficient because it has to be able to count more than the natural
word size. Everything else is efficient even though everything else
also needs to handle values larger than the natural word size. Yes,
makes sense. Or then not.
  Besides, not everything *has* to be reference-counted.
> Most
> reference counts.
  Doesn't sound like a very smart thing to do. Sounds like over-optimization.
  And incidentally many (most? all?) garbage-collected languages will force
every single class to be allocated dynamically (which will add at the
very least the type or size of the object to be stored alongside it
so that it can be properly freed), which in turn forces every object
to be handled through at least one reference (which will add the size
of a pointer to the total memory consumption of the object), plus they
also usually automatically make every object dynamically bound (which
will add at least the size of some kind of pointer to the total memory
consumption of the object).
  Even by a rather conservative estimate we could estimate that each
object requires at least 12 bytes of overhead in such a language. But
of course that is nothing to worry about. The size of a reference count
on the other hand is something to be very worried about.
Date: 13 Sep 2006 20:35:21
Message: <20060914013526.72c43e50@mekanori.mon.istic.org>
> Orchid XP v3 <voi### [at] devnull> wrote:
> > I think he's hinting that finding the right pivot is the "hard" part
> > of the algorithm, and if you get that wrong you get poor
> > performance...
> But that doesn't make quicksort a bad sorting algorithm.
Exactly. So, the lesson we learn from this is the following: An
algorithm or system for which you have to work hard to avoid
pathological cases can still be useful.
Now, if we remember the above, and apply it to Andy's statement:
> I have no idea why after all these years people still think reference
> counting is a good idea. It's so trivial to find an example where it
> utterly fails...
then it is easy to see why after all these years people still think
reference counting is a good idea.
I thought my original reply was both concise and clear, but maybe I was
the only one to think that.
It is often said in teaching that if you tell someone something he'll
forget it almost immediately, but if you make him work it out for
himself he will remember for longer.
"Listen to your users, but ignore what they say." - Nathaniel Borenstein
http://surreal.istic.org/          Calm down, it's only ones and zeroes.
Date: 13 Sep 2006 21:19:52
Message: <4508ae38$1@news.povray.org>
Thank you for that lovely strawman.
Um, yes?  So?   You're correct: Where something isn't reference-counted,
the size of the reference counter adds no overhead.
>>Most
>>reference counts.
When you're trying to put 20,000 objects into 64K of ram, yes, it's
actually quite a smart thing to do.
Only semantically.
Only if the semantics of the language aren't already requiring that
information.
That would be incorrect.
>, plus they
That would also be incorrect.
Your ignorance of modern technology in this field is showing.
I didn't say they weren't something to be worried about. I said that
it's *a* thing to be worried about.
Reference counting doesn't solve the problem of knowing when to collect
the garbage. It's inefficient in both time and space, it causes
unpredictable performance by requiring large amounts of time to free
arbitrarily large structures all at once due to cascading reference
counts going to zero, and virtually nobody who knows anything about
garbage collection uses it anymore.
That you could design a system that's even *more* inefficient than
reference counting by not having followed the research over the last 20
years or so of how to do things right should surprise nobody.
Date: 13 Sep 2006 21:29:29
Message: <4508b079$1@news.povray.org>
Unless your reference counter is smaller than the size of a pointer.
Yes, you can build a reference counting system that doesn't overflow, by
allocating a huge amount of space to a counter that is usually less than
4 bits. But since you *still* need some other sort of garbage collection
anyway, why would you waste that much space?
How do you think allocation in a garbage collected system works? Of
*course* there's no fragmentation.
Um, why would it have to "put it somewhere"? The problem isn't "freeing
the object". The problem is running through all the pointers in the
object whose reference went to zero and marking those as freed also.
Once you do what you describe, then you've lost the simplicity of
reference counting, and now you're doing some other sort of garbage
collection. (Which sort depends on how/when you free the objects.)
And you still haven't solved the major problem, which is that reference
counting DOES NOT WORK.  Reference counting, even with sufficiently
large counters, does not free all the garbage, even if you do it
inefficiently.
There are a number of ways, from simplistic to convoluted. Generally, GC
engines assume they can find the live pointers.
If you're actually interested in the topic, there are good references
freely available. If you're just interested in arguing, I'm not.
Date: 13 Sep 2006 22:21:38
Message: <4508bcb2$1@news.povray.org>
Darren New wrote:
> Most reference-counted systems allocate between five and eight bits for
> reference counts.
Care to provide some credible links/evidence for this claim? It is new to
me, and probably 99% of those using reference counting...
	Thorsten
Date: 13 Sep 2006 22:45:57
Message: <4508c265@news.povray.org>
Smalltalk-80: The Language and Implementation. Or look into any LISP
implementation.
As for a newer reference? Not too many around, as people don't use
reference counting seriously, because it's so flawed. Providing newer
references would be like providing references for bad cache coherency
performance of bubble sorts.
 > It is new to
There's a difference between "a reference-counted garbage-collection
system" and "a program using reference counting."  Certainly, if you
implement it yourself and you have full control over every way you're
going to use it and you don't allocate enough objects that the added
overhead is worth avoiding, then you can use a big counter. People who
build systems that include GC for others to use generally don't get that
luxury. Indeed, people that build systems that include GC generally
don't use reference counting at all, as it (along with mark/sweep) is
pretty much the most primitive lamest inefficient version of GC
possible. But sure, if you're limited by what you can implement in C or
C++ at the application level, it's not too bad, as long as you remember
to manually break cycles everywhere and you're not trying to make it fast.
