POV-Ray : Newsgroups : povray.advanced-users : Normal Map usage Server Time
12 Oct 2025 06:24:47 EDT (-0400)
  Normal Map usage (Message 1 to 9 of 9)
Subject: Normal Map usage
Date: 14 Jun 2006 05:25:01
Message: <web.448fd4dededa1fff270ce0e40@news.povray.org>
how do I setup a material so that it uses a normal map?
REgards,
Thor
Subject: Re: Normal Map usage
Date: 14 Jun 2006 06:00:01
Message: <web.448fddc43881b643270ce0e40@news.povray.org>
> REgards,
> Thor
To be a bit more clear what I meant is to use a normal map texture(with red,
green and blue info for the normal vector infos) instead of a grey scale
bump map Thor
Date: 14 Jun 2006 07:37:21
Message: <448ff4f1@news.povray.org>
> bump map Thor
  Could you be more specific on how you would want the red, green and blue
components of the texture to affect the normals?
Date: 14 Jun 2006 11:35:00
Message: <web.44902bf23881b643270ce0e40@news.povray.org>
> > bump map Thor
Hmm like in all other 3d packages where you use normal maps instead of bump
maps
the renderer uses it to identify the axis of the "Bump" and therefor
delivering
a far better result here is a good explanation of this issue:
http://planetpixelemporium.com/tutorialpages/normal.html
regards,
THor
Date: 19 Jun 2006 03:00:01
Message: <web.44964afa3881b6432dd2aee50@news.povray.org>
Hi Warp,
did the link(http://planetpixelemporium.com/tutorialpages/normal.html)
help to understand what I wanted?
THor
Date: 19 Jun 2006 03:16:15
Message: <44964f3f@news.povray.org>
red,
> bump map Thor
Unfortunately, POV-Ray doesn't support this sort of normal map format.
I've seen a utility which can convert normal maps into height maps, but I
can't seem to find it now... =(
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 Jun 2006 04:21:16
Message: <44965e7c@news.povray.org>
> red,
>> bump map Thor
Maybe you mean this one:
http://66.70.170.53/Ryan/heightmap/heightmap.html
Tim
aka "Tim Nikias"
Date: 20 Jun 2006 17:30:01
Message: <web.449868893881b64354a00b890@news.povray.org>
> red,
> > bump map Thor
>  - Slime
I just hope that they implement it or to implement displacement mapping,
either one would make me very happy :-D
Thor
Date: 17 Jul 2006 02:31:28
Message: <44bb2ec0$1@news.povray.org>
I did, thanks!
 - Slime
