POV-Ray : Newsgroups : povray.advanced-users : Get function from a height_field to define height dependent colors? Server Time
19 Dec 2025 06:23:38 EST (-0500)
  Get function from a height_field to define height dependent colors? (Message 1 to 5 of 5)
Subject: Get function from a height_field to define height dependent colors?
Date: 18 May 2006 17:35:01
Message: <web.446ce78e2fa6fdce71103870@news.povray.org>
I like evaluate values from a height_field image:
something like
#declare f=function(x,y) { height_field { tga "mountains.tga" } }
with x,y between [0,1].
Is this possible?
I like to use this function to define colors dependent from the height
(e.g. starting with blue for sea level, green for middle values, gray for
high values, and white for snow on top of the mountains.
A second idea is to calculate a gradient from this function, in order to
define the color from the steepness of the landscape (e.g. on steep
passages there is no grass because there is no soil...).
Thanks for help,
Icetoaster
Subject: Re: Get function from a height_field to define height dependent colors?
Date: 18 May 2006 18:05:03
Message: <e4iqta$o1r$1@chho.imagico.de>
Icetoaster wrote:
> Hi,
> something like
That won't work.  The only way to use an object in a function is with
the object pattern.  But what you probably want is something like:
#declare f=function { pattern { image_pattern { ... } } }
> Is this possible?
This is much easier, simply use a vertical gradient.
That's what the slope pattern is for.  There are sample scenes coming
with POV-Ray that show how this works (for example
textures/patterns/slopemt.pov).
http://www.imagico.de/ (Last updated 04 May. 2006)
Date: 18 May 2006 18:07:23
Message: <446cf01b@news.povray.org>
> something like
  How would this be different from simply reading the image map directly
(as a pigment function) converted to grayscale?
  Heightfields are, after all, calculated from precisely that info.
  Wouldn't it be much easier to simply apply a "gradient y" texture map
to the heightfield directly?
  You can create a texture which depends on the slope of an object by using
the slope pattern (details in the documentation).
Date: 18 May 2006 18:40:00
Message: <web.446cf7acfdb94041e71103870@news.povray.org>
Thanks a lot for your help!
I have not seen the wood for the trees... :-)
Date: 18 May 2006 22:55:51
Message: <446d33b7$1@news.povray.org>
"Icetoaster" <icetoaster_at_gmx.de> wrote in message
news:web.446cf7acfdb94041e71103870@news.povray.org...
You can try "woods.inc" for starters, then develop your own from there :P
-tgq
