POV-Ray : Newsgroups : povray.advanced-users : spline question Server Time
18 Nov 2025 13:16:49 EST (-0500)
  spline question (Message 1 to 9 of 9)
Subject: spline question
Date: 6 May 2006 07:05:00
Message: <web.445c828e6f6753c5443403d30@news.povray.org>
My question is: in povray does splines (linear,quadratic or cubic) permit to
define only curves or surface also?
and, if it's possible to use splines to define a surface, does its degree
have to be the same in "u" and "v" directions? or, for example, can I
define a spline surface that has degree 1 in one direction and degree 2 in
the other one?!?!
Thanks
Leo
Subject: Re: spline question
Date: 6 May 2006 07:17:52
Message: <WfWW4EA5WIXEFwRC@econym.demon.co.uk>
>the other one?!?!
Spline functions themselves are always curves, not surfaces.
You can use splines in an isosurface function to draw surfaces that are
controlled by spline functions. You could use splines of different types
to control the x and z coordinates. In the third example on this page I
could just as well have used the x values from one spline and the z
values from a spline of a different type.
http://www.econym.demon.co.uk/isotut/more.htm
Mike Williams
Gentleman of Leisure
Date: 6 May 2006 07:27:45
Message: <445c8831@news.povray.org>
  A spline is by definition a curve.
  You can use splines to create eg. meshes (that isn't even too difficult,
just requires some SDL coding). You can also just use bicubic patches which
use bezier splines.
Date: 6 May 2006 09:15:00
Message: <web.445ca0915792ee8a443403d30@news.povray.org>
Ok I've read this page and I find it very interesting...but if I try to put
this piece of code in a .pov file the result isn't similar to the image in
this site...
my pov file is:
location <10, 10, -10>
look_at <0, 0, 0>
light_source { <25, 25, -100> color rgb 1 }
#declare S = function {
   spline {
     natural_spline
      -1, < 0.5, 0, 0.0>,
    -0.5, < 0.2, 0, 0.4>,
    0.01, < 0.2, 0, 0.2>,
     0.5, < 0.4, 0, 0.4>,
       1, < 0.0, 0,-0.6>
isosurface {
  function { y - S(x).x - S(z).z }
 contained_by { box { -10, 10 } }
 pigment{Red}
Have you got any idea?!?!
Thanks
Leo
Date: 6 May 2006 10:09:41
Message: <2dV+IAA13KXEFwVu@econym.demon.co.uk>
>this site...
>my pov file is:
>camera {
>look_at <0, 0, 0>
>   spline {
>     natural_spline
>      -1, < 0.5, 0, 0.0>,
>       1, < 0.0, 0,-0.6>
>isosurface {
> pigment{Red}
Your spline is only defined between -1 and +1, so in the regions outside
that, the spline evaluates to zero, so the isosurface is just {y - 0}
and you get a flat plane.
Either change to contained_by {box {-1,1}}
  and zoom in
  and increase your max_gradient to 2
Or use   function { y/10 - S(x/10).x - S(z/10).z }
  and decrease your max_gradient to 0.25
Or arrange for your spline to cover the whole of the region that you're
going to render
   spline {
     natural_spline
     -10, < 5, 0, 0>,
      -5, < 2, 0, 4>,
    0.01, < 2, 0, 2>,
       5, < 4, 0, 4>,
      10, < 0, 0,-6>
Mike Williams
Date: 6 May 2006 12:05:00
Message: <web.445cc8d05792ee8a443403d30@news.povray.org>
>   and zoom in
> going to render
>    spline {
>      natural_spline
>      -10, < 5, 0, 0>,
>       -5, < 2, 0, 4>,
>     0.01, < 2, 0, 2>,
>        5, < 4, 0, 4>,
>       10, < 0, 0,-6>
> Mike Williams
thanks mike, this message is very helpful for me.
I've got another problem, now:
I know every information of a spline:
- I know the degree (2)
- I know the coordinates of each control point (9 in total)
0 3.000000e-01 0.000000e+00 1.000000e+00
3.000000e-01 3.000000e-01 0.125000e+00 7.071070e-01
3.000000e-01 0 0.250000e+00 1.000000e+00
3.000000e-01 -3.000000e-01 0.37500e+00 7.071070e-01
0 -3.000000e-01 0.50000e+00 1.000000e+00
-3.000000e-01 -3.000000e-01 0.625000e+00 7.071070e-01
-3.000000e-01 0 0.750000e+00 1.000000e+00
-3.000000e-01 3.000000e-01 0.875000e+00 7.071070e-01
0 3.000000e-01 1.000000e+00 1.000000e+00
- I know the knot partition (12 knot in total)
0.000000e+00
0.000000e+00
0.000000e+00
2.500000e-01
2.500000e-01
5.000000e-01
5.000000e-01
7.500000e-01
7.500000e-01
1.000000e+00
1.000000e+00
1.000000e+00
How should I combine (from a mathematical point of view) these information
to obtain the same spline on povray?
So, in which manner I have to fill the sequent statement?
spline {
     natural_spline
thanks
leo
Date: 6 May 2006 15:54:48
Message: <y4UvRAAzzPXEFwHT@econym.demon.co.uk>
>0.000000e+00
>0.000000e+00
>0.000000e+00
>2.500000e-01
>2.500000e-01
>5.000000e-01
>5.000000e-01
>7.500000e-01
>7.500000e-01
>1.000000e+00
>1.000000e+00
>1.000000e+00
I've no idea what any of your terminology means.
What is a degree?
Why do your control points have four dimensions rather than three?
What is a knot partition?
Mike Williams
Date: 6 May 2006 16:24:06
Message: <445d05e6$1@news.povray.org>
> What is a degree?
Mike,
I think his questions may be related to his two recent threads about
NURBS in POV-Ray:
Subject: mesh&nurbs question...
Date: 4 May 2006 14:00:01
http://news.povray.org/povray.advanced-users/thread/%3Cweb.445a0800e57eb53272071f7b0%40news.povray.org%3E/
Subject: how to use nurbs on povray?!
Date: 3 May 2006 16:15:00
http://news.povray.org/povray.advanced-users/thread/%3Cweb.4458d6962d01a59e72071f7b0%40news.povray.org%3E/
Tor Olav
http://subcube.com
Date: 7 May 2006 06:25:01
Message: <web.445dca145792ee8a443403d30@news.povray.org>
degree, control point and knot partition are tipical parameters used to
describe a spline curve...
> What is a degree?
the degree of a spline is the maximum degree of each polinomial
interpolation functions that define the spline...linear spline has degree
1...quadratic spline has degree 2...etc
ignore the fourth number...
It's a set of number that specify the subdivision of the spline's parametric
domain...
In povray, referring to spline statement..
spline {
     linear_spline | quadratic_spline | cubic_spline
      -1, < 0, 0.5, 0.0>,
    -0.5, < 0, 0.2, 0.4>,
    0.01, < 0, 0.2, 0.2>,
     0.5, < 0, 0.4, 0.4>,
       1, < 0, 0.0,-0.6>
the degree is specified by the spline's type...
-1,-0.5,0.01,0.5,1 determine the knot partition...
< 0, 0.5, 0.0> , < 0, 0.2, 0.4> , < 0, 0.2, 0.2> , etc... are control points
coordinates...
I hope you can undertand better my problem now...
Leo
