POV-Ray : Newsgroups : povray.advanced-users : coordinates simplified SCRIPT ? Server Time
9 Feb 2026 01:33:17 EST (-0500)
  coordinates simplified SCRIPT ? (Message 1 to 9 of 9)
Subject: coordinates simplified SCRIPT ?
Date: 20 Jan 2006 16:25:00
Message: <web.43d154886a561f48ca1ca0bb0@news.povray.org>
+   It's been a while since I used POV...
I've always found it enjoyable, and worked
through any inconsistencies encountered...
but now, on starting to use it again, Im
wondering if somebody hasn't already come
up with a plugin or script to allow ALL
the coordinates to be entered in the same
basic mode ?
     As it is, one system is required for
object point locations... another for moving
objects... another for camera or lights...
as I say, all this becomes obvious after a
test render - but wouldn't it simplify matters
to use ONE coordinate system ?  Maybe not...
I could see putting the CAMERA in another
quadrant, for example... comments... suggestions ?
Subject: Re: coordinates simplified SCRIPT ?
Date: 20 Jan 2006 17:17:34
Message: <43d1617e$1@news.povray.org>
> basic mode ?
Sorry, I'm not able to make much sense of what you are saying here.
As far as I know POV-Ray has only one 3 dimensional coordinate system.
This system is global. It is used for objects, cameras, light sources
and most other places IIRC.
(One could argue that another 3 dimenensional coordinate system is used
for specifying colors, but I don't think that this makes the other
system inconsistent.)
If you are sure that you have not misunderstood the POV-Ray manual
(and/or the difference between point- and vector-coordinates), could you
then show an example of what you find inconsistent ?
Btw.: I hope that you are aware that most places (except inside
functions) you are free to choose if you want to write 3D-coordinates
like this: <10, -3, 0> or like this: (10*x-3*y).
Tor Olav
http://subcube.com
Date: 20 Jan 2006 17:39:51
Message: <43d166b7$1@news.povray.org>
stu nous apporta ses lumieres en ce 20/01/2006 16:22:
> basic mode ?
Camera, light(s) and objects all use the same coordinates.
Translations are deltas between the original location and the desired location.
Rotations are around the origin <0,0,0> and expressed in degrees around the 3 axis.
Positive been
anti-clockwise when looking toward the positive direction of the corresponding axis
(lefthanded
system, just like my maths profs taught me)
+X = right
+Y = UP
+Z = AWAY
Don't take life too seriously, you won't get out alive.
Date: 21 Jan 2006 16:50:00
Message: <web.43d2ab94429a1667525a2080@news.povray.org>
> > basic mode ?
> Tor Olav
> http://subcube.com
++  Thanks Tor, for your reply.  It seems we are discussing
the same issue, so Im sorry to have confused you.  Yes -
that would be what I wanted - all according to the same
system - but it simply isn't so with my present installed
version of povray... it is possible I have gotten a broken
code, or otherwise messed with things by mistake.
     I will try to put together a small example later...
your answer is suprising to me though... maybe I should just
start using whatever version you do  :)
Date: 21 Jan 2006 16:55:00
Message: <web.43d2ad29429a1667525a2080@news.povray.org>
> > basic mode ?
Positive been
(lefthanded
> +X = right
> +Y = UP
> +Z = AWAY
> Alain
+++  Another replier agreeing with what I'd like to have, but dont :)
Yes... x/right y/up z/deep  is how I learned it also... going by
this produces very unpredicatable results with my currently installed
POV however.  Thanks for your reply.  I'd say I'll look carefully
at this, but after a dozen or more scripts, all with this same,
I'd long accepted it was how the POV worked... maybe I've got a
rare buggy version ?
Date: 22 Jan 2006 10:14:24
Message: <43d3a150$1@news.povray.org>
stu nous apporta ses lumieres en ce 21/01/2006 16:52:
Positive been
(lefthanded
>>+X = right
>>+Y = UP
>>+Z = AWAY
>>Alain
Please, post a sample scene showing your problem.
Post in povray.binaries.scene-files
Calvinism: Shit happens because you don't work.
Date: 22 Jan 2006 10:45:00
Message: <web.43d3a746429a166b53199180@news.povray.org>
x/right y/up z/deep is povraydefault but you can have your coordinatesystem
just as you prefer it by simply defining the up and right vector in the
camera statement appropriate (as long as they are perpendicular). that way
you can also switch righthanded/lefthanded coordinatesystem.
maybe it's really a buggy version. some code would help much to solve that
Regards Roman
Date: 23 Jan 2006 15:30:00
Message: <web.43d53bbd429a166d962b56b0@news.povray.org>
***   Well, firstly, I'd like to thank all those
 who took time to reply to my question... I was
 learning to work around it, but gratified to see
 everyone agreeing it shouldn't be this way...
   ...and, indeed, I have discovered the real
 problem !  :)
     I had borrowed an *.inc file from one of the
 examples, and was using this for all my new
 renders... after looking more carefully at this
 I discovered it had several keyword specifiers in
 it which were, for each scene, adding a rotation
 and a changed view... hahaha... it's a little funny
 actually, but I'm glad to have "fixed" my broken
 POV, and thanks again to all who offered help.
> basic mode ?
Date: 23 Jan 2006 17:22:20
Message: <43d5571c@news.povray.org>
>  problem !  :)
Hehe, cool! Those problems can drive you crazy. I once had a dying CPU,
it kept giving me memory faults, only they didn't crash POV, they just
messed up my SDL sources when rendering! I kept getting weird syntax
errors in perfectly valid code. Boy, that was scary :)
Florian
