POV-Ray : Newsgroups : povray.advanced-users : Maximum amount of variables passed through command line Server Time
11 Jan 2025 01:43:48 EST (-0500)
  Maximum amount of variables passed through command line (Message 1 to 4 of 4)
Subject: Maximum amount of variables passed through command line
Date: 26 Oct 2005 02:20:00
Message: <web.435f1ee853f9728336a46a7d0@news.povray.org>
I have a very urgent question. I want to know the maximum amount of
variables I can passed through the command line e.g shapes.pov +w100 +h100
#declare=posx=10 #declare=posY=100. Like posx and posy, how many such
variable declarations can I put in the command line?.Is there a limit or is
it unlimited?
Suppose, there was no restriction, what will be the side effect of pushing
very large amount of variables through the command line, in terms of
processing speed and quality?
I have a second question. I made some models in Moray with very smooth
curves using bezier. But when I exported the model to Povray, the curves
get distorted to such an extent that it was impossible to use it. Is there
any remedy to this?
Thanks in advance
Subject: Re: Maximum amount of variables passed through command line
Date: 26 Oct 2005 05:55:35
Message: <435f5297$1@news.povray.org>
"SSSUTM" <nomail@nomail> wrote in message
news:web.435f1ee853f9728336a46a7d0@news.povray.org...
>... I want to know the maximum amount of
> is it unlimited?
AFAIK, it's unlimited; however, it's a lot easier to put everything into a
.ini file - there's less chance of mastikes and orrers that way :-)
None whatsoever. The command line is processed before evrything else happens
(if you see what I mean) and no back-reference is made to it from then on.
> any remedy to this?
Sorry, can't help there. I don't use Moray
John
Run Fast
Run Free
Run Linux
Date: 26 Oct 2005 06:25:47
Message: <435f59ab$1@news.povray.org>
Oops, need to clarify and I quote:
"On computers running Microsoft Windows XP or later, the maximum length of
the string that you can use at the command prompt is 8191 characters. On
computers running Microsoft Windows 2000 or Windows NT 4.0, the maximum
length of the string that you can use at the command prompt is 2047
characters."
And for (?all) modern Unices probably around 3Mb characters - see
http://www.accesspdf.com/article.php/2005020713040824
John
Run Fast
Run Free
Run Linux
"Doctor John" <doc### [at] linuxmailorg> wrote in message
news:435f5297$1@news.povray.org...
>> +h100
>> is it unlimited?
>> pushing very large amount of variables through the command line, in terms
>> of processing speed and quality?
> happens (if you see what I mean) and no back-reference is made to it from
> then on.
>> there
>> any remedy to this?
> John
> Run Fast
> Run Free
> Run Linux
Date: 26 Oct 2005 15:16:55
Message: <435fd627$1@news.povray.org>
I'm not sure what you're using this for, but if you're using it to pass
some data from a program into the scene, why not write it to a file
(already in POV-Syntax) and just include that file? It sure's a lot
easier to handle and more portable, because the maximum length of
commands varies with different OS's.
HTH,
Florian
