POV-Ray : Newsgroups : povray.advanced-users : ridgedMF trouble using Pov3.6 with megapov 1.2 Server Time
12 Oct 2025 11:59:40 EDT (-0400)
  ridgedMF trouble using Pov3.6 with megapov 1.2 (Message 1 to 4 of 4)
Subject: ridgedMF trouble using Pov3.6 with megapov 1.2
Date: 19 Aug 2005 10:05:01
Message: <web.4305e681632772b115b9d80a0@news.povray.org>
I have the following code segment:
#declare f = function {"ridgedMF", <1, 2, 5, 1, 1>}
#declare sea = function {y - 5 * f(0.2 * x, 0.2 * y, 0.2 * z) / 10 - f(x, y,
z)/10 - f((x - 0.15)/0.2,(y - 0.15)/0.2, (z - 0.15)/0.2)/100}
the entire image code was originally rendered using an older version of
POV-Ray and MegaPOV 0.7,
PROBLEM IS...now trying to run this with Povray 3.5 or 3.6 using megapov 1.0
or 1.2, i ALWAYS get a stupid parse error right here:
#declare f = function {"ridgedMF", < <----ERROR
Parse Error: Expected 'valid function expression', ( found instead
ANYONE ABLE TO HELP please!?!?
I havent touched povray in a long time and i am very rusty on
this....obviously im stuck at this point, cause it used to run and now it
doesnt :(
p.s. deleting the comma after the quotes still gives the same error.
Subject: Re: ridgedMF trouble using Pov3.6 with megapov 1.2
Date: 19 Aug 2005 10:15:01
Message: <web.4305e902b948bc2bbb95c26a0@news.povray.org>
This syntax was only valid in the ancient isosurface patch and MegaPOV up to
0.7. MegaPOV isn't an official POV-Ray, nor is the isosurface patch.
RTFM, please!?!?
Date: 19 Aug 2005 10:16:16
Message: <4305e9b0@news.povray.org>
Shouldn't that be ridgedMF(1,2,5,1,1) ? Or is this some sort of MegaPOV
syntax? (And if it is, wouldn't it just be easier to detect
function{ridgedMF(1,2,5,1,1)} and handle it however this is handled?)
I also think it might be f_ridged_mf or something along those lines.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 Aug 2005 10:19:52
Message: <rZO55CAAqeBDFwaC@econym.demon.co.uk>
>doesnt :(
When isosurfaces were introduced into the official version of POVRay the
syntax was changed to make it more flexible. There's a list of the
syntax changes at
<http://www.econym.demon.co.uk/isotut/pov35.htm>
See also the Ridged Multifractal example at
<http://www.econym.demon.co.uk/isotut/builtin5.htm#ridged>
Mike Williams
Gentleman of Leisure
