POV-Ray : Newsgroups : povray.advanced-users : deletion during rendering of large objects Server Time
15 Mar 2026 07:29:09 EDT (-0400)
  deletion during rendering of large objects (Message 1 to 3 of 3)
Subject: deletion during rendering of large objects
Date: 14 Mar 2005 11:45:01
Message: <web.4235bf2e2a7923a299761390@news.povray.org>
Hi Folks,
I am interested in simulating coil structures. These are basically randomly
curved cylinders. I am using a program that is doing surface subdivision of
the object into smooth triangles. Providing me with a povray input script
that can reach up to 100.000 lines. So fare so good. I can rotate,
translate and render without a problem. Also defining objects consisting
out of 8 coils is possible. However, trying to group 10 coils is causing
problems. There is no error appearing during rendering but in the final
picture some coil parts are not displayed.
It would be very helpful if somebody could comment on this problem?
Thanks and cheers
Hans
Subject: Re: deletion during rendering of large objects
Date: 14 Mar 2005 13:39:03
Message: <lavKpCA0kdNCFwOg@econym.demon.co.uk>
Wasn't it hans who wrote:
>Hi Folks,
>Thanks and cheers
>Hans
My guess is that it's unlikely that it has anything to do with the size
of the objects. I've used POVRay to render scenes with over 20 billion
smooth triangles (I actually used mesh2, but that's unlikely to be
significant) using lots of copies of objects each that have up to 138000
lines of code.
Do your objects involve transparent bits that might be exceeding the
max_trace_level?
If you're using manual bounding, or doing anything at all unusual with
the bounding, try removing it.
Mike Williams
Gentleman of Leisure
Date: 16 Mar 2005 09:35:00
Message: <web.42384352ac0933ec299761390@news.povray.org>
> >Hi Folks,
> >Thanks and cheers
> >Hans
> lines of code.
> max_trace_level?
> Mike Williams
Hi Mike,
thanks for your suggestions. No transparent objects have been used.
Concerning the bounding I am not avair setting something manuelly.
Regards
Hans
