POV-Ray : Newsgroups : povray.advanced-users : Problem with Mirror and Reflection using photons Server Time
11 Jan 2025 07:38:21 EST (-0500)
  Problem with Mirror and Reflection using photons (Message 1 to 3 of 3)
Subject: Problem with Mirror and Reflection using photons
Date: 18 Jan 2005 03:35:00
Message: <web.41ecc9f82fb492d1173073970@news.povray.org>
Hello,
As I didn't get an answer on povray.newusers maybe it is a advanced problem:
I have a problem using Photons to simulate a laser beam which is reflected
by a mirror. Please take a look at the povray example at the end of this
message. If you calculate the example, you will notice that the reflected
laser beam does not start at the point where the incomming beam hits the
mirror, but somewhere above the mirror, this looks not very natural. What
is wrong with my example?
And second question, how can I achieve that the reflected beam is not so
much scattered?
Thanks in advance for your answers,
Peter
help.pov:
global_settings {
   adc_bailout 0.0039216
   assumed_gamma 1.5
   noise_generator 2
   photons {
      count 2000
      gather 40, 100
      media 100, 2
   perspective
   location <0, 5, -5>
   sky <0, 1, 0>
   direction <0, 0, 1>
   right <1.3333, 0, 0>
   up <0, 1, 0>
   look_at <5, 0, 0>
light_source {
   <4, 5, -5>, rgb <1, 1, 1>
   media_interaction off
   media_attenuation off
light_source {
   //*PMName Light
   <0, 0, 0>, rgb <1, 1, 1>
   cylinder
   radius 0.3
   falloff 0.3
   tightness 0
   point_at <8, 0, 0>
   photons {
      refraction on
      reflection on
box {
   //*PMName Interior
   <0, -4, -4>, <8, 4, 4>
      color rgbft <0, 0, 0, 1, 1>
   interior {
      media {
         method 3
         intervals 1
         ratio 1
         scattering {
            1, rgb <1, 1, 1>
            extinction 0
   scale 1
   rotate <0, 0, 0>
   translate y*0.5
   hollow
union {
   //*PMName Mirror
   box {
      <-0.1, -1, -1>, <0.1, 1, 1>
         color rgb <0.188235, 0.188235, 0.188235>
   box {
      //*PMName MirrorPiece
      <-0.101, -0.5, -0.5>, <0.101, 0.5, 0.5>
         color rgb <0.701961, 0.52549, 0.384314>
      finish {
         ambient rgb <0, 0, 0>
         diffuse 0
         reflection {
            rgb <1, 1, 1>
      photons {
         target
         refraction on
         reflection on
         collect off
   rotate z*135
   translate x*6
Subject: Re: Problem with Mirror and Reflection using photons
Date: 18 Jan 2005 04:58:25
Message: <41ecddc1$1@news.povray.org>
"Peter T. Mayer" <nomail@nomail> wrote in message
news:web.41ecc9f82fb492d1173073970@news.povray.org...
> much scattered?
Hiya. Stumbling across your question here, hopefully I'll have the right
answer.
Probably only a matter of adding a samples value so try that to prevent
missing or artifact prone media. Oftentimes it needs to be 50 or more-- slow
as that may be. At least I don't believe raising max_trace_level would help
since this is only a few surfaces.
As to the scatter, well, it could be that you need to increase 'tightness'
of your laser light. You might try using the 'parallel' keyword, too,
although I don't think this will change anything in this scene as it is now.
I've rendered your script and tried a few things. Looks like that frame
around the mirror could be confused as incorrect media appearance too, but
what happens is that the illuminated media only seems brighter with that
behind it. The grayness against the blackness makes a brightness change.
However, media samples 100 really helps (photons part left the same).
Bob H.
Date: 20 Jan 2005 13:20:01
Message: <web.41eff595d8c6c599fb71872a0@news.povray.org>
> answer.
Thank you for your answer, the solution works well.
Nevertheless I m not very satisfied with the result. If you look at the the
original beam you can see, that he is slightly transparent, not so the
reflected beam.
Thanks,
Peter
