The mention of glass confused me, was thinking of plate glass turned edge-on
and yet this being about a blob shape I thought of something rounded.
If it were like a microscopic view of a plant cell I imagine this would be
about the extinction of light across denser places along line of sight. What
Mike suggests could work, I guess, just that I was thinking of media getting
thicker at the outer edge of a spherical shape and thinner in the middle.
Much like the Earth's atmosphere, as seen from orbit.
If you fill the object with media uniformly then the opposite will happen.
That is, if not only a shell. So, it would seem a shell is needed. The shape
of the blob object might make that difficult. A sphere alone would be very
simple, though, by using the 'spherical' pattern in the density_map.
Well, I don't have any brilliant ideas to share really, just wanted to
elaborate this question a bit. However, I do have a little scene of a plant
cell-like thing showing an example of media filling a blob. Should be
obvious enough to understand. Basically just a positive strength sphere and
negative strength side spheres to make it boxy and 'boxed' patterns for both
surface color and interior. Feel free to do whatever you want with this if
it is any good at all for what is needed. If not, continue asking... maybe
at povray.general or povray.newusers, too, since there's more traffic there.
/* BEGIN */
global_settings {
assumed_gamma 1
location -5*z
look_at 0
angle 50
rotate <30,30,0>
light_source {
-1000*z, 1
rotate <30,-30,0>
plane { // floor
y,-2/3
rgb 1
// plant cell?
blob {
threshold 0.5
sphere {
0,1.75,1
boxed
color_map {
[0.45 color rgbt <0.1,0.6,0.1,0.9>]
[0.55 color rgbt <0.6,0.1,0.1,0.3>]
scale 1.3
sphere {
0,1,-1
scale <0.5,2,2>
translate x
sphere {
0,1,-1
scale <0.5,2,2>
translate -x
sphere {
0,1,-1
scale <2,2,0.5>
translate z
sphere {
0,1,-1
scale <2,2,0.5>
translate -z
sphere {
0,1,-1
scale <2,0.5,2>
translate y
sphere {
0,1,-1
scale <2,0.5,2>
translate -y
color rgb 1
interior {
media {
method 2
// samples 10
absorption <0.9,0.1,0.9>*9
emission <0.1,0.9,0.1>
scattering {
4, rgb 4
// eccentricity 0.2
// extinction 0
density {
boxed
density_map {
[0.45 color rgb <0.6,0.1,0.1>*0]
[0.55 color rgb <0.1,0.6,0.1>*1]
[0.65 color rgb <0.1,0.6,0.1>*0]
scale 1.3
hollow
/* END */
