POV-Ray : Newsgroups : povray.advanced-users : Camera positioning Server Time
26 Mar 2026 03:22:44 EDT (-0400)
  Camera positioning (Message 1 to 4 of 4)
Subject: Camera positioning
Date: 17 Dec 2004 05:45:00
Message: <web.41c2b67e219a48abce1a9020@news.povray.org>
I'm currently working on a project that generates povray scenes
programmatically. These scenes can vary in overall dimensions, and I am
having diffculty calculating a camera position that incorporates every
element of the scene, without introducing lots of space around the edges.
Is there a way to calculate the position of the camera, knowing what
direction it should point in. My 3d trig. just isn't up to the challenge.
Values that are known are:
 - A list of scene extremities as 3d coordinates (e.g. a simple block would
have 8 extremities)
 - The camera angle (set at 20 degrees)
 - The direction the camera should point in
 - The aspect ratio
I would appreciate any comments/suggestions(or solutions :) )
Subject: Re: Camera positioning
Date: 17 Dec 2004 08:33:26
Message: <41c2e026$1@news.povray.org>
> have 8 extremities)
>  - The aspect ratio
There may be a simpler way to do this, but basically here's what you
have to do:
1. Recalculate your scene bounds in camera space. Camera space is
defined by the matrix
| < right vector>     |   |                           |
| < up vector>        | * | camera translation matrix |
| < direction vector> |   |                           |
To convert from scene space to camera space, take the inverse of that
matrix and multiply each corner of your original bounds by that. Note
that the result of these calculations will make the camera move along
its "direction" vector, so you want to choose a translation matrix that
makes the direction vector intersect the center point of your scene
(unless you desire an offset. Then you can recalculate your bounds by
taking the new max and min of these points in the "camera" x, y and z
directions.
2. Now that you have the new bounds it's simple trig to determine how
far away the scene box needs to be from the camera to fit inside the
view frustum. From this you can calculate a vector from the camera
location (<0,0,0> in camera space) to center of the original scene box.
3. Perform the inverse of the camera space transformation on the vector
and add this vector to the center of your viewspace. This gives you the
correct camera location.
This may be easier to digest in a diagram. I'm sure there's something on
the Internet, or I could put something together if you want. Also, POV
may have some built in functions that handle the transformations/bounds
for you.
Derek
Date: 29 Dec 2004 09:05:01
Message: <web.41d2b921e563b829bce1a9020@news.povray.org>
> have to do:
> directions.
> for you.
> Derek
Thanks Derek.
I think a diagram would be useful as I am not very familiar with matrices.
I'm finding it quite difficult to get my head round different coordinate
systems.
I don't really understand how to get the 'camera translation matrix' when
the distance from the scene to the camera position is an unknown.
Thanks for your help,
Kevin.
Date: 7 Jan 2005 09:11:38
Message: <41de989a@news.povray.org>
Normally, I prefer the other way round: First create a scene with a
dummy object in it (like box { <-1,-1,-1>,<1,1,1> }) and manually adjust
your camera so that this object is captured as you want.
Now if you want to create a picture of another object, pick it's largest
extremity and scale the whole object by 1/extremity, so that it fits
inside the object you calibrated the camera for.
HTH,
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
