POV-Ray : Newsgroups : povray.advanced-users : Wake... Server Time
12 Oct 2025 14:41:34 EDT (-0400)
  Wake... (Message 1 to 5 of 5)
Subject: Wake...
Date: 3 Nov 2004 16:05:00
Message: <web.4189473dbfaefadca54c62600@news.povray.org>
I tried this over in the new user area and didn't hear much.  Maybe I'm
slowly graduating over here, but I'd be the last person to call me an
advanced user. Anyways on with the question...
   I'm creating an image of an object flying very fast over a plane.  I want
to create the sense the the object is flying close enough to the surface
that there is a small force gripping the plane and dragging it along
behind.  I'm thinking something like the wake left behind by a boat. But
something closer to an airplane flying at supersonic speeds near a
perfectly still surface then a slow row boat for example.  I'm pretty sure
I need an Isosurface but that's about all I know at the moment.  Can
someone help me get started or point me to something that might help?
By the way, if it will help here is the plane that I'm currently using:
  #declare Foo = function {min(abs(x)-int(abs(x)),abs(z)-int(abs(z)),
                 1-(abs(x)-int(abs(x))),1-(abs(z)-int(abs(z))))}
  #declare grid = plane {y, 0
      function { Foo(x, y, z) }
      color_map {
        [0 color White]
        [0.01 color White]
        [0.02 rgb <0, 0.05, 0>]
        [0.98 rgb <0,0.05, 0>]
        [0.99 color White]
        [1 color White]
    scale 500
    normal { bumps 0.01 scale 30 }
    finish {
      ambient .1
      diffuse .5
      reflection .55
      specular 1
      phong 1
I'm thinking that something that disturbs the whole surface or maybe even
something that just grabs and disturbs the grid lines would work equally
well.  Ideally this is something I might like to animate but that is
probably something I can work out after I figure out how to get the effect
I want.
Thanks,
Carl
Subject: Re: Wake...
Date: 4 Nov 2004 20:28:11
Message: <418ad72b$1@news.povray.org>
Hi Carl!
Fascinating problem... I wanted to learn something about isosurfaces
anyways, so have a guess what I spend my evening on :)
You can find an image of my experiments in p.b.images, the scene file is
in p.t.scene-files. It's heavily commented, but if you got questions,
feel free to ask...
HTH & Thanks for this nice task ;)
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Date: 5 Nov 2004 11:05:00
Message: <web.418ba3961c301785a54c62600@news.povray.org>
Thank you so much.  Here is the first pass of the image I'm working on.  I
wanted to share:
http://www.wwwmwww.com/TRON/dayflyer.png
Off to check out what you've done and to see if I know enough to know how to
apply it.
Thanks again,
Carl
Florian Brucker <tor### [at] torfboldcom> wrote:
> Hi Carl!
> feel free to ask...
> Florian
Date: 5 Nov 2004 14:43:07
Message: <418bd7cb$1@news.povray.org>
> wanted to share:
> apply it.
Hey, that's nice...
(Very 80s)
Date: 5 Nov 2004 18:30:00
Message: <web.418c0cac1c301785a54c62600@news.povray.org>
Thanks,
Carl
> > wanted to share:
> > apply it.
> Hey, that's nice...
> (Very 80s)
