POV-Ray : Newsgroups : povray.advanced-users : Vector Components Server Time
18 Nov 2025 20:47:39 EST (-0500)
  Vector Components (Message 1 to 6 of 6)
Subject: Vector Components
Date: 15 Sep 2004 16:05:01
Message: <web.4148a03fe2a5f8e58b2587f70@news.povray.org>
I am trying to make a function which uses a vector cordnate return a value.
Within this the I am trying to pull the y component of the input to do a
compareson on it.  I have tried with both #if and #switch and have the same
problem.
#declare MyFn = function {
  #switch ( y )
    #case ( 1 )
      // funcion code 1
    #break // 1
    #case ...
  #end // switch
Parse Error: Float expected but vector or color expression found.
Is there a vector function I can use to get they y component, MyFn.y, <y> or
such?
 Thorcane
Subject: Re: Vector Components
Date: 15 Sep 2004 16:09:25
Message: <4148a175@news.povray.org>
>   #switch ( y )
>     #case ( 1 )
>       // funcion code 1
>     #break // 1
>     #case ...
>   #end // switch
> such?
Hmm... that's not gonna work.
The #switch executes at parse time, whereas the rest of the function
executes at trace time. In other words, you can use a switch that
depends on a constant defined somewhere else (e.g., animation frame
number), but *not* on a parameter to the function.
(The exact error you're seeing is because "y" has two meanings in
POV-Ray. Usually y = <0, 1, 0> - *except* inside functions, where "y"
suddenly means the 2nd parameter to the function. But only at trace
time, not parse time. Confused? POV-Ray is!)
Andrew @ home.
Date: 15 Sep 2004 16:30:00
Message: <web.4148a5d120945ceb8b2587f70@news.povray.org>
Not exactly what I wanted to hear.  I guess I will have to work out a new
function  to do what I wanted.
Thank you.  If anyone has any suggestions to make the original work please
feel free to post.
 Thorcane
Date: 15 Sep 2004 17:24:07
Message: <4148b2f7$1@news.povray.org>
You should read the thread "How to get a texture like (y>0.8 & z>0.9) ->
texture a      else -> texture= b?" by D. H. Berlin in povray.newusers on
9/3/2004 11:23 AM. He had a nearly identical problem. The solution is
probably the select() function.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 15 Sep 2004 17:31:49
Message: <4148b4c5$1@news.povray.org>
> feel free to post.
I suggest that you read about about user defined functions and
2.2.1.6.3 Declaring User-Defined Float Functions:
http://www.povray.org/documentation/view/3.6.1/231/
2.2.1.3.4 Functions:
http://www.povray.org/documentation/view/3.6.1/228/
Here's a simple example:
#declare MyFn =
   function(x, y, z) {                         // Or just: function {
     select(y - 1, 0, SomeExpression, 0)  +    // Case: y = 1
     select(y - 2, 0, OtherExpression, 0) +    // Case: y = 2
     select(y - 2, 0, 0, YetAnotherExpression) // Case: y > 2
You may also have a look at my reply in this thread in p.b.s-f:
Subject: Discontinuous functions?
Date: 14 Aug 2004 11:19:55
http://tinyurl.com/6vaar
http://news.povray.org/povray.binaries.scene-files/message/%3C411fd33c%40news.povray.org%3E/#%3C411fd33c%40news.povray.org%3E
Tor Olav
http://subcube.net
http://subcube.com
Date: 22 Sep 2004 14:45:50
Message: <4151c85e@news.povray.org>
Ah... I forgot about this. Yes, that would seem to be the answer. (I was
trying to construct something using the abs() and sign() functions to
achieve the same result...)
Andrew @ home.
