POV-Ray : Newsgroups : povray.advanced-users : 3D modelling hardware Server Time
29 Sep 2024 00:18:33 EDT (-0400)
  3D modelling hardware (Message 1 to 5 of 5)
Subject: 3D modelling hardware
Date: 6 Aug 2004 14:15:01
Message: <web.4113c9732920292a4785f90d0@news.povray.org>
Okay, not really talking about dedicated 3D input devices. What I mean to
ask is, has anyone thought of or perhaps even done modelling with
multiple-view camera setups?
What I have in mind is building a clay or plastic model then photographing
it using a digital camera. This setup would include the following:
1. the real-world model containing marked control points for surface
extrapolation
2. a camera, moving around the model in an arbitrary fashion, taking
pictures along the way (not necessarily in a pre-defined path)
3. a marker - a small model, such as a transparent cube, which would model
the origin and axes. This marker would serve as reference for the scale and
orientation for every photograph
Now, what I'd like the tools, with which to accomplish this task, to do is
to calculate the marked points on the model. This process would not be
fully automated, rather each image would first be reviewed by the user and
the user him/herself would mark the appropriate points on the photograph of
the model to define the 2D points which correspond to specific 3D points on
the model. Also, the user would need to mark the "origin cube" to define
reference points. After this stage of point-and-mark is done, the program
calculates the 3D points for each of the photographs and uses statistical
analysis to determine the most likely position of a point on the model.
I'm not looking for depth-of-field algorithms to produce dense 3D models;
just the points, so I can model, say, NURBS surfaces using those reference
points. I've looked at some sites offering some image rectification and
affine transformation with projection, but they're all built for dense 3D
reconstruction.
Here's one example:
http://www-sop.inria.fr/robotvis/personnel/qdelam/ArticleFG98html/Article.forhtml.html
It concerns moving a modelled hand to fit the depth-of-field produced by the
program.
Any information regarding these kinds of calculation? I guess I'm not alone
on this subject, who hasn't thought of simplifying modelling to, actually,
child's play? ;)
Thanks,
-Klemen
Subject: Re: 3D modelling hardware
Date: 11 Aug 2004 11:57:25
Message: <411a41e5$1@news.povray.org>
> mean to ask is, has anyone thought of or perhaps even done modelling
> with multiple-view camera setups?
> photographing it using a digital camera. This setup would include the
> following:
> extrapolation
> model the origin and axes. This marker would serve as reference for
> the scale and orientation for every photograph
> do is to calculate the marked points on the model. This process would
> not be fully automated, rather each image would first be reviewed by
> the user and the user him/herself would mark the appropriate points
> on the photograph of the model to define the 2D points which
> correspond to specific 3D points on the model. Also, the user would
> need to mark the "origin cube" to define reference points. After this
> stage of point-and-mark is done, the program calculates the 3D points
> for each of the photographs and uses statistical analysis to
> models; just the points, so I can model, say, NURBS surfaces using
> those reference points. I've looked at some sites offering some image
> rectification and affine transformation with projection, but they're
> all built for dense 3D reconstruction.
> Here's one example:
> by the program.
> alone on this subject, who hasn't thought of simplifying modelling
> to, actually, child's play? ;)
http://mi.eng.cam.ac.uk/research/vision/photobuilder/aim.html
Might be useful.
Date: 13 Aug 2004 05:55:00
Message: <web.411c8ff0a4b90f8b4785f90d0@news.povray.org>
> Might be useful.
Yeah, I took a look at that... but haven't gotten far with that, since
there's no concrete mathematical model in place, only a few sketches.
Thanks anyway, I'll keep looking.
Date: 31 Aug 2004 19:33:18
Message: <41350abe@news.povray.org>
> extrapolation
I've looked into this stuff a bit... isn't that the dream? Take a few
photographs and then spit out a model? :)
Anyways, what I've seen done is a grid of laser light points is
projected over the object. Using a grid of laser lights means that the
points are always projected with known distances between them to aid in
the calculations...
I can't find the page, but some guy was also trying to build his own
homebrew digitizer. I think it was mentioned on slashdot if you'd like
to search for it (I can't at the moment). Basically the object was
rotated on a pedestal while a laser line was scanned vertically over it
and used as a contour shape to be pulled from the captured images.
The thing I'd REALLY like to see (and wouldn't it help with this too?)
is to be able to take a pair of stereo photographs and then have an
algorithms spit out a depth of field image... They're doing it for the
mars rovers, but...
Arlo
Date: 15 Dec 2004 18:35:21
Message: <41C0CA37.3040609@chen-becker.org>
Check out Paul Debevec's page:
http://www.debevec.org/Research/
It sounds kind of like what you want, but I believe it may not work for
all models.
Derek
