is there any way to evaluate the complexity of a scene in povray 3.5 with an
absolute measure like triangles as in opengl?
The complexity of the scene code for the parser can be measured by the
number of tokens (as reported by POV-Ray). There is no way to measure
the complexity of a scene for the renderer, you can have a scene of just
256 bytes without fancy loops and macros that takes hours to render, see:
http://astronomy.swin.edu.au/~pbourke/povray/scc3/final/
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
There is no way to have a precise complexity "measurement".
Although this concept is very relative, there are two major standard
measures: the memory used by the algorithm and the time spent by the
algorithm
In POV-Ray, both measures depends on the primitives used, and in the
combination of them. For instance, using photons may increase both memory
and time by a factor of 2 or 3 (or even more...), but its usage corresponds
to a very few tokens.
I guess that the only way to measure the scene "complexity" is rendering it
and measuring memory peaks and the time spent in the rendering process.
> algorithm
You can easily create a scene in POV that uses only a few 100k of memory
and takes days to render.
And both are no way measures for the complexity of a scene. One of the
most loved (and most hated) things about POV-Ray is that there are
always multiple ways to accomplish a certain effect. To find the most
efficient way is what Poving is all about...
