POV-Ray : Newsgroups : povray.advanced-users : Variable IOR issue Server Time
9 Feb 2026 10:48:52 EST (-0500)
  Variable IOR issue (Message 1 to 7 of 7)
Subject: Variable IOR issue
Date: 15 Dec 2003 20:55:02
Message: <web.3fde64febc9e52f427bbadf50@news.povray.org>
Hi.
I'm trying to simulate variable IOR in POV-Ray by putting several cylinders
inside each other. I wanted to make a bullet-trail macro, wich would draw
the effect of heated air when a bullet crosses it. I've created the macro,
and the result is attached.
The basic idea was making the ior fall to 1.0 along the trail, and along the
axis, so the center of the trail would look more heated than the edges. To
achieve it, I've sudbivided the trail in N sub-trails, each made of M
co-axial cylinders. Each subdivision was made by creating cylinders with
distinct ior, the inner the greatest, falling from MaxIOR in the middle, to
1.0 in the edge.
Thus, all I had to do was create the N sub-trails, along the trail's path,
giving different values to MaxIOR, so the heat would drop with the distance
to the bullet.
That can be seen quite well in the picture.
But there are some problems. The max_trace_level variable must be set too
high, and if I set it over 220 it gives me stack overflow :(
Besides, the refraction between two sub-trails is shown, wich gives an
undesired toroidal aspect.
Anyone come up with a solution / idea / sugestion?
Thanx a lot
link to the picture: http://mega.ist.utl.pt/~lmfe/pictures/bullet_trail.png
link to the scene: http://mega.ist.utl.pt/~lmfe/pictures/bullet_trail.pov
Subject: Re: Variable IOR issue
Date: 16 Dec 2003 15:33:08
Message: <MPG.1a49175df4510ea698994b@news.povray.org>
In article <web.3fde64febc9e52f427bbadf50@news.povray.org>,
lmf### [at] megaistutlpt says...
I got a 403 Forbidden on these.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 16 Dec 2003 16:00:03
Message: <web.3fdf71245be44e5727bbadf50@news.povray.org>
I'm sorry.... it's fixed now :p same links...
Date: 17 Dec 2003 12:05:02
Message: <web.3fe08b655be44e572ff34a90@news.povray.org>
Couldn't you try applying a well-chosen normal pattern to a simple thin box
(aligned with the bullet but facing the camera as far as possible) with a
single ior? I also had this variable ior problem a long time ago, but
controlling the refraction with a normal pattern or more directly by
choosing an appropriately shaped object proved faster and didn't have the
max_trace_level problem. I've used this to generate "heat-wave" type
distortions in a horizon line and simulate odd lenses.
Date: 17 Dec 2003 13:30:01
Message: <web.3fe09fc35be44e5727bbadf50@news.povray.org>
Well... I've seen one animation of a heat wave in this newsgroup. The main
problem is that, in my case, the effect of the variable refraction is not
covered in all the camera viewing area. This
means that a box or a plane with a disturbed normal just won't work
I'm wondering if I can simplify the scene, speed up the rendering and
decrease memory, all at once by changing POV's source code, and doing an
alternative method of "refraction". This method would not follow any
physical law, but it would change the direction of the ray by evaluating
some noise at the intersection point. So, the ray direction will be changed
when it passes through the object, making it look "refracted".
In fact, the model isn't very realistic (because no physics are used at
all), but in this case, when the heated air's density is random, it would
not look very strange. Of course, it would need some tweaks, as taking in
account the direction of the ray vs. the normal to make it more realistic,
and maybe the distance the ray travels through the refracting object.
This is a model wich came up in my simple mind, so any sugestions are
largely welcome.
I apologize if I wasn't clear enough. Any questions?
Thanks in advance
Leonardo
Date: 19 Dec 2003 05:40:01
Message: <web.3fe2d56e5be44e572ff34a90@news.povray.org>
Ah, you're worried about seeing the "sharp edges" of the refracting object?
I'm not sure that the refraction calculation is slow compared to calling a
noise function.
Date: 19 Dec 2003 09:15:01
Message: <web.3fe307165be44e5727bbadf50@news.povray.org>
Yes, that's exactly what I don't want: sharp edges... and I can't figure it
out how to get rid of them without several cylinders... Maybe it could be
faked by disturbing the normal, so the rays that hit the edges are just
transmitted, but it would require a lot of work finding such
transformation, and it would be camera-position dependant, wich is bad...
>noise function.
It would be faster than having 5 or 10 refracting cylinders, one inside each
other. That's what I meant
And it would give better, smoother results, if the noise were applied
correctly... no sharp edges ;)
