POV-Ray : Newsgroups : povray.advanced-users : Materials that blur Server Time
23 Feb 2025 07:41:48 EST (-0500)
  Materials that blur (Message 1 to 10 of 18)
Subject: Materials that blur
Date: 18 Sep 2003 15:30:01
Message: <web.3f6a075848b4e2fa6099662b0@news.povray.org>
Is there any way to implement materials that blur the image behind them?
Making it less transparent doesn't distort the image, just lets less of it
through.  Same thing happens with media.. just changes intensity/color of
light, but not its path.
The degree of blur should be related to the path length of light passing
through a material so surface distortions won't work right.
Please email replies to kev### [at] dukeedu
Thanks,
Kevin
Subject: Re: Materials that blur
Date: 18 Sep 2003 17:14:55
Message: <3f6a204f$1@news.povray.org>
IOR + surface normal will simulate, say, frosted glass. (For a real frosted
look, use scattering media inside it. But that's not necessary for the
distortion.)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 18 Sep 2003 17:47:18
Message: <MPG.19d3d4318fbc4a509898b8@news.povray.org>
In article <web.3f6a075848b4e2fa6099662b0@news.povray.org>,
kev### [at] dukeedu says...
Hmm. There is an idea.. How about extending IOR, which is basically a
function of the surface itself, so that you can use patterns to create
permutations and noise in the value? Could be an interesting effect and
placed on a small enough scale it would possibly create such a blur
effect. Of course I have no clue how to code such a thing myself. :(
Sigh...
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 19 Sep 2003 08:02:26
Message: <3f6af052@news.povray.org>
  Yes:
http://tag.povray.org/povQandT/languageQandT.html#blurredreflection
  (Even though it talks about blurred reflection, it can be used for
blurred refraction as well, as the text mentions at the end.)
  If you post a question to a newsgroup you should check the newsgroup
for answers and not expect people to deliver the answers to you personally.
Date: 21 Sep 2003 23:55:01
Message: <web.3f6e71fa78c6ab4a6b3dbbc0@news.povray.org>
>  Yes:
Thanks Warp,
That seems to do the trick.  I was concerned that a surface texture might
not meet the criteria of blurring more as the path length in the material
increases.  I've run a few tests and at least for some simple test cases it
seems to do a pretty good job.
-Kevin
Date: 22 Sep 2003 10:10:02
Message: <web.3f6f022a78c6ab4ec80a3da0@news.povray.org>
Kevin wrote:
Well Ok, doesn't quite meet the specifications.
The amount of blur doesn't increase with path length, rather it increases
with the difference in the normals of the front and back surfaces.
Makes for a pretty nice blur tho... one observation is that if you put the
blur texture on the interior then you can get unblurred reflections and
blurred refractions.
What we need to modify this code with is a function that sets the blur
amount that is related to the optical path length of the ray through that
object at whatever point it is rendering.  That way the blur amount can
vary.
I haven't a clue how to implement this.. it might require a patch.
Date: 22 Sep 2003 16:09:28
Message: <3f6f56f8@news.povray.org>
  What do you mean by "path length"?
  The blurred refraction trick blurs the background more if it's farther
away than if it's closer. I don't understand what else you are after.
Date: 22 Sep 2003 20:22:11
Message: <cjameshuff-BEAA31.20201722092003@netplex.aussie.org>
In article <3f6f56f8@news.povray.org>, Warp <war### [at] tagpovrayorg>
I think he's trying to simulate scattering throught a material. The
probability of a photon getting scattered in a random direction
increases with the length of its path through the material, and can
occur at any point inside the material. Blur textures only simulate
surface scattering, like ground glass.
This type of scattering would be quite expensive to compute, since it
would involve tracing many rays for each transmitted ray. You could
simulate it by using several surfaces with the blurry texture in the
interior of the object, but POV has no built-in facility for doing this.
Date: 23 Sep 2003 22:10:01
Message: <web.3f70fc1178c6ab46be419860@news.povray.org>
Chris has the right idea... what I'm looking for is a material that blurs
the image more if the ray has to pass through a lot of the material rather
than just a tiny bit.
I agree that to do this the right way would be really expensive, but a quick
way around it might be to determine the length of the ray that passes
through the material and then set the local blur size (for that ray) to
some function of the path length.
Hmmm.... maybe if you could define a gradient of the normal bump sizes you
could simulate this effect.. or by playing with normal maps... I'll have to
fiddle with that.
Christopher James Huff wrote:
>In article <3f6f56f8[at]news.povray.org>, Warp <war### [at] tagpovrayorg>
>Christopher James Huff <cja### [at] earthlinknet>
>http://home.earthlink.net/~cjameshuff/
>POV-Ray TAG: chr### [at] tagpovrayorg
Date: 24 Sep 2003 02:38:28
Message: <3f713be4@news.povray.org>
What real-life material does this?
IMHO blurring normally only occurs on surfaces.
Lutz-Peter
