POV-Ray : Newsgroups : povray.advanced-users : Using lathe or SOR with an elliptical object Server Time
13 Oct 2025 01:35:17 EDT (-0400)
  Using lathe or SOR with an elliptical object (Message 1 to 5 of 5)
Subject: Using lathe or SOR with an elliptical object
Date: 20 Aug 2003 15:15:01
Message: <web.3f43c86f4e495bb8aa8c3f990@news.povray.org>
I've been working on a POV model of a football stadium:
http://www.henrywagner.org/povray/images/POPMart2.htm
http://www.henrywagner.org/povray/images/POPMart3.htm
Currently the model is generated using the POV scripting syntax to generate
the stadium out of triangles in the shape of an ellipse. As I add more
details, the number of triangles is getting out of control. Today it hit
me, I could just define the points that make up the profile and "sweep" the
stadium out with lathe or sor, but I haven't been able to figure out how to
create the elliptical shape. One idea is to create a spherical stadium and
use "scale" to stretch it along one axis, but I don't think that will look
right. Is there away to sweep an object along an elliptical path? Any other
ideas of how to speed this up?
Henry
Subject: Re: Using lathe or SOR with an elliptical object
Date: 22 Aug 2003 05:56:20
Message: <3f45e8c4@news.povray.org>
"HenryW" <pov### [at] henrywagnerorg> wrote in message
news:web.3f43c86f4e495bb8aa8c3f990@news.povray.org...
generate
the
to
other
I passed this message up before thinking someone would give you some kind of
answer before now. I was thinking perhaps something Tor Olav Kristensen has
done in the past might help. Mainly because he's done some great things with
manipulating POV-Ray objects. Unfortunately I'm not finding the exact thing
to show you. Only this:
http://news.povray.org/povray.general/23254/
But there's also 'prism', which could be plotted out into a ellipse and be
made conical at the same time. Might take a little learning if you're
unfamiliar with it but that would be my best suggestion.
Well, maybe you can adjust this one:
// stadium
prism {
  conic_sweep
  cubic_spline
  0.5,         // height 1
   1,         // height 2
  22,           // number of points
/* now the uv vectors */
// inner
  < -0.5, -1.5>*0.9,
  < 0,  -2>*0.9,
  < 1, -1.5>*0.9,
  < 1.25,  0>*0.9,
  < 1,  1.5>*0.9,
  < 0,  2>*0.9,
  < -1,  1.5>*0.9,
  < -1.25, 0>*0.9,
  < -1,  -1.5>*0.9,
  < 0, -2>*0.9,
  < 0.5,-1.5>*0.9,
// outer
  < -0.5, -1.5>,
  < 0,  -2>,
  < 1, -1>,
  < 1.25,  0>,
  < 1,  1>,
  < 0,  2>,
  < -1,  1>,
  < -1.25, 0>,
  < -1,  -1>,
  < 0, -2>,
  < 0.5,-1.5>
     pigment {rgb 1}
scale <1,0.667,1>
Date: 22 Aug 2003 14:35:01
Message: <web.3f4661b438fa04f1a0c272b50@news.povray.org>
>news:web.3f43c86f4e495bb8aa8c3f990[at]news.povray.org...
>generate
>the
>to
<snip>
Or maybe a combination of the two... Make spline of your profile, then make
a lathe object and union it with prisms made from the same spline. Prism
requires a closed spline so you probably have to use lathe rather than SOR.
RG
Date: 29 Aug 2003 19:15:01
Message: <web.3f4fddba38fa04f1aa8c3f990@news.povray.org>
>>generate
>>the
>>to
><snip>
>RG
Thanks for the tips! Currently I'm working on the triangle based version,
though I think I'm going to need more memory ;-)
Henry
Date: 5 Sep 2003 14:46:17
Message: <3f58d9f9@news.povray.org>
Would scaling a traditional SOR be acceptable?
> Hi,
generate
the
to
other
> Henry
