POV-Ray : Newsgroups : povray.advanced-users : Transforming Objects with a Matrix Server Time
19 Nov 2025 02:49:06 EST (-0500)
  Transforming Objects with a Matrix (Message 1 to 8 of 8)
Subject: Transforming Objects with a Matrix
Date: 11 Jun 2003 09:55:01
Message: <web.3ee733dbf3c076d14fbaca0c0@news.povray.org>
Is it possible to transform any object (or group of objects) by a 3x3 or 4x4
matrix in POV SDL?
I wrote a realtime application about steeringbehaviors in 3D space (Open GL)
and now I want to be able to export movements to POV to create
photorealistic animations (polygon models will be reset by predefined POV
objects). My program handles transformations with matrices. So a function
that works like the camera's look-at would do the trick (the matrix stores
the up-, right- and direction-vector).
Any Idea?
Subject: Re: Transforming Objects with a Matrix
Date: 11 Jun 2003 09:58:31
Message: <e6deev0od0mpml3jgni3l8bmknm66andft@4ax.com>
> matrix in POV SDL?
What about looking into documentation for keyword 'matrix'?
http://www.povray.org/search/?s=matrix
ABX
Date: 11 Jun 2003 11:48:32
Message: <3ee74f50$1@news.povray.org>
rtfm is always a good idea, however, in this case the manual says:
6.3.1 Transformations
The supported transformations are rotate, scale, and translate.
but should read
The supported transformations are rotate, scale, translate and matrix.
[Not very advanced, though...]
>>matrix in POV SDL?
> ABX
Date: 11 Jun 2003 11:57:02
Message: <01keevo266rnodnnbl5os6okb5v6097rrd@4ax.com>
On Wed, 11 Jun 2003 17:48:31 +0200, sascha <sas### [at] userssourceforgenet>
> but should read
It says correct IMO. Imagine I have baloon. I can do following transformations:
a) rotate it turning around
b) translate it by moving
c) scale it with blowing
but I can't matrix it becouse there is no transformation 'matrix' in reality,
though matematically I can describe this transformations with matix and that's
what is written in next sentence "A transformation matrix may also be used to
specify complex transformations directly." :-)
ABX
Date: 11 Jun 2003 13:25:01
Message: <web.3ee7653e7beff2cefed43e8b0@news.povray.org>
Thanks. Sorry, I was sure that matrix transformation is not supported by pov
(never read about it before), so I didn't search it in the documentation.
Now it will be easy :)
'bye
Date: 11 Jun 2003 15:55:19
Message: <3ee78926@news.povray.org>
> transformations: a) rotate it turning around
> reality, though matematically I can describe this transformations with
> matix and that's what is written in next sentence "A transformation matrix
> may also be used to specify complex transformations directly." :-)
Maybe
d) an arbitrary *affine transformation* specified by a matrix
would be the correct terminology.
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 12 Jun 2003 02:03:19
Message: <3ee817a7$1@news.povray.org>
>>but should read
>ABX
(6.3.1.4  Matrix Keyword)
... the matrix command allows more general transformation effects like
/shearing/. The following matrix causes an object to be sheared ...
The manual could be changed to make this clearer
The supported transformation modifiers are |rotate|, |scale|,
|translate|, and matrix. They are used to turn, size and move an object
or texture. A transformation matrix may also be used to specify complex
This would clear up the meaning of "may also be used" (for complex
transformations) instead of (is also supported).
Tim Attwood
Date: 12 Jun 2003 02:40:11
Message: <qq7gev8nnbtnf8417qla8mdq52o5u8mubv@4ax.com>
On Wed, 11 Jun 2003 23:04:47 -0700, Tim Attwood <tim### [at] worldnetattnet>
http://www.cs.berkeley.edu/~ug/slide/pipeline/assignments/as5/transforms3d.shtml#shear_rot_scale_rot_scale
ABX
