POV-Ray : Newsgroups : povray.advanced-users : UV Mapping and Layered Textures Server Time
15 Mar 2026 03:47:40 EDT (-0400)
  UV Mapping and Layered Textures (Message 1 to 4 of 4)
Subject: UV Mapping and Layered Textures
Date: 6 May 2003 16:30:05
Message: <web.3eb81af726e9d0da8d9df90f0@news.povray.org>
I read this in the Help for POV-Ray 3.5:
You create layered textures by listing two or more textures one right after
the other. The last texture listed will be the top layer, the first one
listed will be the bottom layer. All textures in a layered texture other
than the bottom layer should have some transparency. For example:
  object {
    My_Object
    texture {T1}  // the bottom layer
    texture {T2}  // a semi-transparent layer
    texture {T3}  // the top semi-transparent layer
I use a script to export scenes from Blender and render using POV-Ray
version 3.5.
Is it possible to use UV Mapping and use layered textures together? If so
how? Can anyone provide a simple example? A cube would suffice.
An example would be like a metal box, that has dirt or rust on it. One layer
has the metal texture, one layer has the dirt/rust texture. I'd like to see
them blend or use transperency somehow if possible.
Any help would be appreciated. Or if someon tell me to go and soak my head,
I can do that too!
Subject: Re: UV Mapping and Layered Textures
Date: 7 May 2003 04:12:30
Message: <3eb8bfee$1@news.povray.org>
web.3eb81af726e9d0da8d9df90f0@news.povray.org...
Just declare your layered texture beforehand.
#declare MyLayeredTexture=texture{...}texture{...}texture{...}
and then use it as usual.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 7 May 2003 16:20:09
Message: <web.3eb96a4848966ef48d9df90f0@news.povray.org>
Gilles Tran wrote:
>web.3eb81af726e9d0da8d9df90f0[at]news.povray.org...
>G.
>- POV-Ray and Poser computer images
>- Posters
Thank you very much for your reply. I really admire your work. It is
oustanding.
I will see if I can figure out what I need to do based on your response.
Thanks again.
Date: 7 May 2003 16:25:07
Message: <web.3eb96b3a48966ef48d9df90f0@news.povray.org>
>G.
>- Posters
Thank you for your reply. I really admire your works, they are outstanding.
I'm not a experienced POV-Ray user just yet, but hope to be. I will see if I
can figure out what I need to do based on your coments.
Thanks again.
