POV-Ray : Newsgroups : povray.advanced-users : strange texture result on CSG object containing a blob Server Time
13 Oct 2025 06:43:59 EDT (-0400)
  strange texture result on CSG object containing a blob (Message 1 to 2 of 2)
Subject: strange texture result on CSG object containing a blob
Date: 9 Jan 2003 13:55:41
Message: <web.3e1dc475adadb2c4992bea00@news.povray.org>
Hi !
I've got this problem and can't find a way to solve it.
My aim is to create a thin slice which looks as if it was cut out of the
"Dummy"-object (blob).
This slice should be less transparent in the middle of its surface and
become more transparent to the brim. (Therefore the "Glow" and "Glow2"
textures)
Actually this slice should have no or nearly no thickness. This can be
controlled by setting the length of the "Mirror2" cylinder to 0.01 or
something like that.
I only set it to 4 to make my problem more obvious.
I first thought the "cutaway_textures" parameter could solve the problem but
it only made it worse.
I hope someone can help me adjust the scene to suit my needs or maybe show
another better method to do the thing I want to do.
I'd be very glad to get some help cause this is part of a bigger
scene/animation and the
problem has stopped my progress in writing it.
Thanks in advance
Bert
And here's the code:
#include "textures.inc"
light_source
  <10, 20, -20 >//<-10, 20, -20 ><0, 20, -20 >
  color red 1.0  green 1.0  blue 1.0
camera
  location  <10,0, -23> // position of camera <X Y Z>  //-23
  direction 2.0*z            // which way are we looking <X Y Z> & zoom
  up        y                // which way is +up <X Y Z>
  right     4/3*x            // which way is +right <X Y Z> and aspect ratio
  look_at   <0, -0.5,  0> // point center of view at this point <X Y Z>
#declare Glow=pigment{ wood
                    color_map { [0.00   color Orange filter 0 ]
                                [0.05 color Orange filter 0 ]
                                [0.15 color Orange filter 1 ]
                                [1 color Orange  filter 1]
                    rotate y*90
#declare Glow2=pigment{ onion
// create a smooth blobby shape
#declare RadiusVal   = 5.0; // (0 < RadiusVal) outer sphere of influence on
other components
#declare StrengthVal = 1.0; // (+ or -) strength of component's radiating
density
#declare Dummy=
blob {
  threshold 0.6
  cylinder { <-6.125,0,0>,<6.125,0,0> , RadiusVal, StrengthVal texture
{pigment {Glow scale RadiusVal}} translate -y*6.125 }
{pigment {Glow scale RadiusVal}} translate -y*6.125 rotate z*90}
{pigment {Glow scale RadiusVal}} translate -y*6.125 rotate z*180}
{pigment {Glow scale RadiusVal}} translate -y*6.125 rotate z*270}
  sphere { <-6.125,0,0>, RadiusVal, -StrengthVal texture {pigment {Glow2
rotate z*45
#declare theatre=
sphere {
  <0, 0, 0>
  1
  texture {Bright_Blue_Sky scale <0.2,0.1,0.2>}
  scale 100
  hollow
//#declare Mirror = plane { x,0 rotate -z*0 translate -x*2 }
#declare Mirror2=cylinder { <0, 0, 0>, <3, 0, 0>, 20 rotate -z*0 translate
-x*4 }
intersection {
        object { Dummy   }
        object {Mirror2  }
        cutaway_textures
//no_shadow
object { theatre }
//object { Dummy }
Subject: Re: strange texture result on CSG object containing a blob
Date: 9 Jan 2003 14:26:46
Message: <3e1dccf6@news.povray.org>
"Bert" ha scritto
: intersection {
:         object { Dummy   }
:         object {Mirror2  }
:         cutaway_textures
: //no_shadow
: object { theatre }
: //object { Dummy }
Not sure it's what you want. But instead of the intersection try:
object { Dummy clipped_by {object {Mirror2}} }
