POV-Ray : Newsgroups : povray.advanced-users : Radiosity flouroescent lighting troubles Server Time
19 Nov 2025 07:16:37 EST (-0500)
  Radiosity flouroescent lighting troubles (Message 1 to 10 of 47)
Subject: Radiosity flouroescent lighting troubles
Date: 19 Nov 2002 18:50:14
Message: <web.3ddaccae46e653f8b2769afa0@news.povray.org>
I hope someone can help me with a problem I'm having with illuminating my
scene with flourescent lights using radiosity.
I'm re-creating my living room in pov-ray, and the problem I'm having is
with the radiosity illumination of the flourescent lights. The lights are
basically made using 160*2.5 cm cylinders with white pigment and high
ambient. A cross-section of the location of the lights in the scene is in a
kind of like this:
  ___
|___|
I can't seem to get them to illuminate the scene enough. The real-world
lights produce sufficent lighting, but the virtual ones don't. I've cranked
the ambient value of the lights up to pow(10,30), and still the
illumination is too dark. I tried using light sources in a line instead of
high ambient, but the results didn't look very realistic. I have been
trying for 3 days to try and solve this without any luck. Here is the
radiosity block from my scene:
  radiosity {
    pretrace_start 0.08
    pretrace_end   0.4
    count 1600
    nearest_count 8
    error_bound 1.0
    recursion_limit 2
    low_error_factor 0.5
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 1
    //max_sample -1000
    adc_bailout 0.01/pow(10,30)
    //always_sample off
    //normal on
    //media on
I sure would like some help with this problem. I would post comparison
images in the binary group, if I had a digital camera and the web interface
allowed attatchments.
Rohan _e_ii
Subject: Re: Radiosity flouroescent lighting troubles
Date: 20 Nov 2002 00:04:15
Message: <3ddb17cf@news.povray.org>
"Rohan Bernett" <rox### [at] yahoocom> wrote in message
news:web.3ddaccae46e653f8b2769afa0@news.povray.org...
> ambient.
You could try using a high diffuse value, since that is what radiosity will
be working with instead of the ambient. Although it isn't likely to be
completely right without actual light sources.
Your error_bound might have to be 1/10 to help with blotchiness. Your count
is pretty high, seems to me anyway because I typically use a count of under
1000 or even under 500.
Why is gray_threshold at 0 (off)? Are you trying to prevent color bleed,
thus perhaps dark things into the light? Something I'm unsure would be
affective or not.
Farewell,
Date: 20 Nov 2002 03:01:25
Message: <3ddb4155@news.povray.org>
  You shouldn't dump a possible solution just because a first experiment
didn't succeed.
  Can you be more precise about what you tried and why it didn't look good?
Did you try with area_lights (which should be quite dense and naturally
use adaptiveness)?
Date: 20 Nov 2002 05:17:59
Message: <n8omtuogk9ec23dnlge1hc9klfv5ee48bi@4ax.com>
On Tue, 19 Nov 2002 18:43:42 EST, "Rohan Bernett" <rox### [at] yahoocom>
100 should be enough, even 10, just make sure you assign the same
value to max_sample as you assign to the ambient, otherwise you're
just limiting the brightness.
Peter Popov ICQ : 15002700
Date: 20 Nov 2002 07:13:59
Message: <3ddb7c87$1@news.povray.org>
"hughes, b." <omn### [at] charternet> wrote in message news:3ddb17cf@news.povray.org...
> affective or not.
gray_threshold at 0 leads to maximum colour-bleed doesn't it? Not 'off'
Andy Cocker
Date: 20 Nov 2002 10:15:49
Message: <3ddba725@news.povray.org>
How about raising recursion_limit a little? If
I'm not mistaken, thats what sets a limit for
light bouncing off of other areas (so your "light-source"
might light the lamp (limit 1) bounce off and hit another
area (limit 2), and thats it. But I could be wrong. Try raising
it to 3 or 4, maybe even 5, and see what happens...
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Radiosity, gray_threshold 0%=0!=off
Date: 20 Nov 2002 13:44:15
Message: <3ddbd7ff@news.povray.org>
"Andrew Cocker" <mai### [at] andrewcockercouk> wrote in message
news:3ddb7c87$1@news.povray.org...
> > affective or not.
Oops. I think I see my mistake. I have been misinterpreting the
documentation on it. Been using very low non-zero values for it all this
time. The part where it says:
"At 0%, this feature does nothing. At 100%, you always get white/gray
ambient light, with no hue."
Obviously it must actually be saying that 0 is same as default and so makes
no change. This could need a rewording because what I think it really means
is that 0% (=0?) is that gray_threshold is not active and thereby not
applying graying. Or something to that effect.
Sure am glad you questioned me about that.
Date: 20 Nov 2002 13:50:34
Message: <chrishuff-FBE294.13491120112002@netplex.aussie.org>
In article <3ddb17cf@news.povray.org>,
Since he is using radiosity as a lighting source, the high ambient is
needed. Diffuse won't do anything if there's no light to diffuse, your
advice would give a black image.
http://tag.povray.org/
Date: 20 Nov 2002 14:03:35
Message: <3ddbdc87@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
will
I see, thanks Christopher. I almost mentioned ambient 1 instead of very high
ambient values because I wasn't sure how the higher than 1 value might
negatively affect the outcome of the render.
Farewell,
Date: 25 Nov 2002 14:20:48
Message: <Xns92D1CE6C55A58raf256com@204.213.191.226>
I alsow played with pure-ambient lights, but there are terribly slow to
render.
In my case the solution was - to use assumed_gamma 1.0 (or even 0.7)
Other thing - swith for a test all textures to pigment rgb .9 and difffuse
.8 or .9
