POV-Ray : Newsgroups : povray.advanced-users : Volume-preserving blob Server Time
29 Sep 2024 14:12:37 EDT (-0400)
  Volume-preserving blob (Message 1 to 10 of 32)
Subject: Volume-preserving blob
Date: 11 Oct 2002 10:05:03
Message: <web.3da6d971ed80a515398d8dbb0@news.povray.org>
(Sorry for the bad engish if you find any; Please correct.)
The POV-Ray blob object does not preserve it's volume when the components
are moved around.
Is it possible to make a blob-like volume-preserving function for the
isosurface?
How about simulating water drops with surface tension?
btw. Is there other blob-alternatives? IMO blob object is smooth in the
wrong way.(?)
Subject: Re: Volume-preserving blob
Date: 11 Oct 2002 10:11:32
Message: <eomdqu4261g1pvajk2a8arg1ftijtbfun9@4ax.com>
> are moved around.
> isosurface?
There is something made by Rune IIRC, check
http://runevision.com/3d/blobs/blobs.asp
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/
> wrong way.(?)
you mean they are not smooth ???
ABX
Date: 11 Oct 2002 10:25:21
Message: <3DA6DF50.C060DEA@gmx.de>
The IsoCSG blob is exactly like the native POV-Ray blob.  There is a
different possibility though described in the POV-Ray docs, section
6.5.4.4.4:
http://www.povray.org/documentation/view/169/#s06_05_04_04_04
Date: 11 Oct 2002 10:35:22
Message: <18odqu072imrgkd452ut43u1aibt9k8fl1@4ax.com>
On Fri, 11 Oct 2002 16:25:20 +0200, Christoph Hormann <chr### [at] gmxde>
except it holds other shapes
ABX
Date: 11 Oct 2002 12:10:00
Message: <chrishuff-B6C788.12060211102002@netplex.aussie.org>
In article <web.3da6d971ed80a515398d8dbb0@news.povray.org>,
> are moved around.
> isosurface?
> wrong way.(?)
I know what you mean. A blob is just an isosurface, it only cares about
the value of a function at a point, not about the volume or surface
area. This is a problem I've been thinking about for a long time.
One possibility would be a particle system with blob particles. Use
enough particles with repulsion between particles that are too close,
and you could get something that does a fairly good job of maintaining
its volume. You end up with blobs of huge numbers of particles though,
it is still "lumpy", and the volume isn't very constant for small groups
of particles. Maybe you could adjust the radius of the components to
compensate for volume changes, this might give a useable approximation.
Some kind of mesh "stretched over" the volume of particles would be
better, and I've been trying to think of a good way to do this. I think
it is a much better approach, it will give smoother results and having
the actual "surface" data available would make things like water beading
on and wetting an object more realistic, and would do a much better job
of avoiding the liquid penetrating the surface of an object. (with
blobs, you only have component data, you don't really know where the
surface is)
Maybe particles aren't necessary, some kind of voxel field containing
"pressure" and "direction" information might be enough. Maybe combine
the two, computing particle forces on a coarse lattice instead of
per-particle.
It could also do a much better job of drops separating and merging: blob
components just stretch towards each other when they are close, and
merge when they are close enough...nothing like the behavior of real
liquid drops.
My basic idea would be a closed ball of "cloth" containing particles.
The cloth-surface interacts with objects and transfers forces to the
particles, and the particles hold the surface up and control its motion.
This would do a fairly good job of simulating a single drop. Dividing
into separate drops or merging separate drops into one could be a much
harder problem...figuring out which triangles to subdivide, which
"bonds" to break, and closing the holes in each sub-drop, or knitting
the surfaces of two drops together...
It would be very slow to compute in POV script, as well as difficult to
write with the limitations of the language, you would need an external
program to generate a mesh.
http://tag.povray.org/
Date: 11 Oct 2002 12:56:10
Message: <11rdqug29h7273cvugl7nln8n3nlbgf9qd@4ax.com>
>are moved around.
You are right, they do not.
>isosurface?
It probably is, but take my word it won't be easy.
These two questions probably have the same answer. You can use a mesh
to make your blob-like object, and using a mesh, you can make a
physical simulation with surface tension, volume preservation and
whatever else you can think of. Take my word on this as well, it's
even harder :)
>IMO blob object is smooth in the wrong way.(?)
What's the correct way to smooth a blob?
Peter Popov ICQ : 15002700
Date: 11 Oct 2002 15:45:16
Message: <web.3da72a3b4cdcaf4d398d8dbb0@news.povray.org>
I don't know what is the *correct* or the perfect way to smooth a blob, but
I just don't like the way the components react to each other sometimes.
Sometimes there is a visible edge between two spheres that isn't as smooth
as the rest of the blob and usually the appearance of the blob is too
smooth.
Of course one can overcome these anoying things by adding more and more
components...
Oh well the blob object is not made to be the ultimate make-everything from
ten spheres thingie. %) I just need to do what I gotta do whit other
objects. Right now I'm expirimenting on spheres in isosurfaces;Gives very
smooth results but takes time to render.
-And thank you all for the aswers so far!
Date: 11 Oct 2002 16:28:46
Message: <3da7347e$1@news.povray.org>
but
> smooth.
This is due to the exact same mathematical property that causes a similar
"grid" artifact in the noise function: first derivatives match up, second
ones don't. It's not an easy problem to solve.
 - Slime
[ http://www.slimeland.com/ ]
Date: 12 Oct 2002 17:28:20
Message: <3DA894B0.9FCA901F@dcs.gla.ac.uk>
Hmm, I'm not sure, but is this not because the blob density function is
quadratic? If the blob function was exponential (e.g a mixture of
Gaussian components), wouldn't the second derivative be continuous? e.g
isosurface with a function like
f_gauss = function(x,y,z) { 1.0 - exp(-(x*x + y*y + z*z)/2.0) }
then use a sum of f_gauss at different centers...
But I could be totally wrong about this...
--John
Date: 12 Oct 2002 18:01:14
Message: <3da89baa@news.povray.org>
> blob density function is quadratic? If the blob
I don't know exponential functions very well, but I agree that it
shouldn't be that difficult to get smooth blobs, and that it would only
require the individual blob components to use functions whose second
derivatives match up.
Correct me if I'm wrong...
Rune
rune|vision:  http://runevision.com (updated Sep 8)
POV-Ray Ring: http://webring.povray.co.uk
