POV-Ray : Newsgroups : povray.advanced-users : Cylindrical radius-light Server Time
13 Oct 2025 11:37:59 EDT (-0400)
  Cylindrical radius-light (Message 1 to 5 of 5)
Subject: Cylindrical radius-light
Date: 26 Sep 2002 10:55:03
Message: <web.3d931f0cf4969a7b6bd4eb880@news.povray.org>
Hi!
Simple (or not) question:
How to make (or simulate effect of) sth I call 'cylindrical radius light'
(probably wrong :)?
Imagine... standard light source placed in <0,0,0> between two infinite XY
planes, and distance between these planes is infinitely small. All rays of
light come radially from the point and are placed on XY plane.
Now add many of this light sources along Z axis, let's say: from z*-1 to
z*1.
Finally we've got 2 units long line of flat lights, placed in Z.
Object enlightened with this source will be in dark for Z over 1 or below
-1.
Shadow cast by this object will make on the {XZ translate -y*delta} plane
sth like cylindrical projection map used in carthography.
OK. It's simple: take two invisible planes (or two discs which is better),
place standard light source between them, scale/squish it, then make 10^n
copies of it along the line. Voila!
But performance will drop down dramatically, and I have no millenium to wait
for the effects.
Is there more simple way?
Regards
__________
 Gregor
Subject: Re: Cylindrical radius-light
Date: 26 Sep 2002 15:04:34
Message: <chrishuff-997E56.15020126092002@netplex.aussie.org>
In article <web.3d931f0cf4969a7b6bd4eb880@news.povray.org>,
> for the effects.
So basically you want a light where the rays come out radially from and
perpendicular to a line segment?
There's no fast way to do this without patching POV. It probably
wouldn't be a very difficult patch, but you would have to convince
someone it is useful enough. A better alternative would be some way to
define this kind of thing in the scene file, using functions...somehow
make the light position and intensity a function of the intersection
point and other information. Really something that needs user-defined
vector functions...which we don't have yet.
http://tag.povray.org/
Subject: Re: Cylindrical radius-light, 1 way 2 do it
Date: 26 Sep 2002 16:04:06
Message: <3d936836$1@news.povray.org>
// bob's little test scene
// fill light (helps to visualize scene)
light_source
        y,0.25
sphere
        0,1
        pigment
                color rgb <1,0.5,0.25>
        translate <0,-1,5>
box
        -1,1
        pigment
                color rgb <0.25,0.5,1>
        scale 5
        translate <0,3,4>
/* light disk macro */
#macro
        CyLite
        (Thickness,Color,FadeDistance,Orientation,Position)
union
light_source
        Thickness*y,Color
        spotlight
        point_at -y
        radius 89.99
        falloff 90
        tightness 0
        fade_distance FadeDistance
        fade_power 1
light_source
        -Thickness*y,-Color
        spotlight
        point_at -y
        radius 89.99
        falloff 90
        tightness 0
        fade_power 1
        rotate Orientation
        translate Position
 // multiple disk lights
#local Count=10;
#while (Count>0)
/* Create the disk of light.
 Thickness, Color, FadeDistance, Orientation, Position */
CyLite ( 0.05, <1,1,1>, 10, <-5,10,-15>*Count, <1,-1,0>*Count/10 )
#local Count=Count-1;
Date: 26 Sep 2002 16:28:05
Message: <3d946a3f.99890364@news.povray.org>
On Thu, 26 Sep 2002 15:02:01 -0400, Christopher James Huff
>> for the effects.
It may be possible with some modifications to the SDL raytracer, but
it'll be sloooow.
/Erkki
Date: 30 Sep 2002 12:50:10
Message: <web.3d987e86e93356d26bd4eb880@news.povray.org>
Thanks, H.B., I've tried it. Nice trick, but... two comments:
A) There are TWO light sources for each stripe, and this slows down
raytracing much more than my 'light-n-disks-o-matic'.
B) There are funny looking effects of light/shade around ANY object placed
in the light cones. Strongly unacceptable.
So I've returned to my light-between-two-disks idea. Needs some
experimenting, but effect is good unless I try to aggregate those
flat-lights into cylinder. Even a hundred of them slows down everything to
infinity. And I need at least 1500-2000 parallel disks in my scene! And what
with media/photons/interior effects? Hell and devils!
Well, allrighty then. There'll be invented new
supercomputer of peanut size until mine POVray ends radiosity calcs!
Maybe much sparse (and fatter) disks'o'light with some kind of image_mapping
over the light_source? Is this possible in POVray? I know this method from
3DStudio.
And maybe some tricky use of parallel lightning in light groups?
I dunno.
If somebody'll find any simple solution to my problem - DO NOT hesitate to
post it!
Thanx
  Gregor
PS. I've got no enough experience to try user-defined vectoring so far, but
thanks for replies anyway - maybe later I'll try to use this clue.
__________
 Gregor
