POV-Ray : Newsgroups : povray.advanced-users : Gouraud Shading??? Server Time
22 Feb 2025 11:55:05 EST (-0500)
  Gouraud Shading??? (Message 1 to 7 of 7)
Subject: Gouraud Shading???
Date: 30 Aug 2002 22:35:03
Message: <web.3d702a8b215c86447aca4b930@news.povray.org>
Hi
I just started learning Pov-Ray and I'm trying out different things. Is
tehre any way I can create Gouraud Shading ??
annelize :-)
Subject: Re: Gouraud Shading???
Date: 31 Aug 2002 06:26:24
Message: <3d7099d0$1@news.povray.org>
Gouraud Shading may be used with smooth-triangles,
look it up in the docs.
Essentially, you give a corner for a triangle plus
a surface normal for every corner, like this:
smooth_triangle{
 Corner_1, Normal_1, Corner_2,Normal_2, Corner_3,Normal_3
POV-Ray will interpolate the normals on the surface.
Its supposedly best to have the normals be unit-length-vectors,
which can be easily achieved with vnormalize().
That's just a rough outline, the docs explain a little more in detail.
Tim
Tim Nikias
Email: Tim### [at] gmxde
"annelize" <ann### [at] tiscalidk> schrieb im Newsbeitrag
news:web.3d702a8b215c86447aca4b930@news.povray.org...
> Hi
> annelize :-)
Date: 31 Aug 2002 07:23:56
Message: <3d70a74b@news.povray.org>
Tim Nikias <tim### [at] gmxde> wrote:
> smooth_triangle{
  That does not do Gouraud shading.
Date: 31 Aug 2002 07:42:45
Message: <3D70ABDD.38ED44F4@pandora.be>
> > smooth_triangle{
In the Gouraud model in each vertex of all triangles a normal is
defined. Using this normals the light intensity in the vertices is
determined and the light intensity in each point of a triangle is an
interpolation of the light intensities in the vertices. The Gouraud
model uses an interpolation of LIGHT INTENSITIES.
In the Phong model (smooth triangles) in each vertex of all triangles a
normal is defined. Using this normals the normal in eacht point of a
triangle is an interpolation of the normals in the vertices. The Phong
model (smooth triangles) uses an interpolation of NORMALS. This model is
better adopted to handle reflection, etc...
Herman Serras
Gent (Belgium)
http://cage.rug.ac.be/~hs/
Date: 31 Aug 2002 10:32:09
Message: <3d70d369@news.povray.org>
Well. What can I say?
Bad me.
*slaps his head, runs against the wall, and ducks from the
neighbour throwing something*
Still, I think the effect is almost the same, isn't it?
Tim Nikias
Date: 31 Aug 2002 11:25:59
Message: <3d70e007@news.povray.org>
Nope, it's completely different.
Interpolating normals, you can get highlights in the middle of a triangle.
Gourond-Shading the same triangle would give a dull, dark triangle.
Highlights can hardly be rendered with gourond shading. (only with many
small triangles, so the highlight is close enough to one of the vertices)
Also, gourond shading doesn't combine good with reflection/refraction etc.
I don't think anyone ever used gourond-shading in a raytracer, since it
doesn't make much sense...
Date: 1 Sep 2002 00:13:17
Message: <pan.2002.09.01.04.10.57.126591.215@gte.net>
On Sat, 31 Aug 2002 10:33:24 -0400, Tim Nikias quoth:
> Bad me.
> *slaps his head, runs against the wall, and ducks from the neighbour
> throwing something*
Nope.  In general, Phong shading is slower and higher-quality than
Gouraud shading.  The Phong shading model is much better for things like
specular highlights.
Mark
