POV-Ray : Newsgroups : povray.advanced-users : Lens flares without third party addons Server Time
9 Feb 2026 22:33:11 EST (-0500)
  Lens flares without third party addons (Message 1 to 10 of 26)
Subject: Lens flares without third party addons
Date: 28 Jul 2002 22:01:02
Message: <web.3d44a1b0b730afe8d02c7b870@news.povray.org>
How do I make a lens flare WITHOUT using a third party addon (like CC's one
or NKFlare)?
Rohan _e_ii
Subject: Re: Lens flares without third party addons
Date: 29 Jul 2002 03:52:39
Message: <0qs9kug6mbrfggv22l780fdkje8ahi4ob5@4ax.com>
On Sun, 28 Jul 2002 22:00:16 EDT, "Rohan Bernett" <rox### [at] yahoocom>
>or NKFlare)?
Make one yourself? :)
Seriously, both Nathan's and Chris' use the same technique - they use
textured discs placed very close to the camera and facing it, so that
they appear in front of all other objects. Every element of the flare
is a disk (or a triangle or a polygon). The positions and coloring are
calculated depending on the parameters you feed (flare type, flare
location, brightness, camera location etc.)
There is a way to make semi-real lens flare using photons. Basically,
you have to reconstruct the geometry of the camera (the optics system
with all its lens and the shutter etc.) and then observe the scene
through it. If you use photons, there will be visible flares in the
image. However, this is very slow, and photons do not model
diffraction so you won't get the most peculiar flare effects at all.
Hope this helps.
Peter Popov ICQ : 15002700
Date: 29 Jul 2002 04:33:08
Message: <3d44fdc4@news.povray.org>
Why do you have to use photons? Wouldn't it also work with simple specular
highlights?
Date: 29 Jul 2002 05:30:10
Message: <6m2akucpltthqdkqgkavh3hei1pksqi90e@4ax.com>
On Mon, 29 Jul 2002 10:29:51 +0200, "Simon Adameit" <gom### [at] gmxde>
>highlights?
No.
For a more precise answer... think about it, why are we using photons
at all? If specular highlights and faked caustics were enough, there
would be no need of photons. Yet there is... I am sure Nathan Kopp,
and Hendrik van Jensen before that, didn't invest years in vain.
Date: 29 Jul 2002 06:27:44
Message: <3d4518a0@news.povray.org>
> No.
But imho lensflares aren't caustics but multiple specular reflections of a
light source.
So why do you need photons to simulate them?
Date: 29 Jul 2002 08:24:22
Message: <3d4533f6$1@news.povray.org>
> light source.
Yes you are right and it can be done but it is very time-consuming and
difficult to get the look you want to acheive using this method.  I have
done it myself.
-tgq
Date: 29 Jul 2002 08:45:05
Message: <3d4538d1@news.povray.org>
> or NKFlare)?
  Why?
Date: 29 Jul 2002 10:10:29
Message: <chrishuff-A4D575.09032529072002@netplex.aussie.org>
In article <3d4518a0@news.povray.org>, "Simon Adameit" <gom### [at] gmxde>
> light source.
Most surfaces wouldn't be directly exposed to the light, so they would
either be in shadow or be getting transmitted light that should have
been refracted or reflected. Highlights alone won't do the job, they
will always look as though they come from light directly from the light
source.
However, I never heard about doing it with photons...my idea of the
technique was always to put a very small reflection on the lens and make
a very bright object or a glow at the light position. That would
simulate all the refraction and reflection and doesn't need photons.
Date: 29 Jul 2002 10:56:13
Message: <jrlaku4gds9bjfijavt2ma99h348knn6nu@4ax.com>
On Mon, 29 Jul 2002 09:03:25 -0500, Christopher James Huff
I think Ron made one with photons.
Date: 29 Jul 2002 17:59:36
Message: <3d45bac8$1@news.povray.org>
> > or NKFlare)?
>   Why?
Why not? I want to spend time on it, I don't want anyone to think that this isn't
completely work of mine, I want to be proud of it and achieving it will make me feel
godlike...
Jonathan.
