POV-Ray : Newsgroups : povray.advanced-users : Issues with area lights and specular highlights Server Time
9 Feb 2026 16:36:22 EST (-0500)
  Issues with area lights and specular highlights (Message 1 to 4 of 4)
Subject: Issues with area lights and specular highlights
Date: 10 Mar 2003 20:48:43
Message: <vq17602ml3qd$.q5xtkfjscixl.dlg@40tude.net>
I've been working on an include file that renders simple lens flares using
POV's specular highlight system and I've encountered a problem: POV only
uses area light attributes for the shadows of objects and not the diffuse
or specular components. I am aware that this is documented in the help file
but it can make many effects not work properly. I'm posting some images to
p.b.s-f showing the problem. If there's no other way to address this, I'll
consider adding a new keyword to my patch.
light_source#macro G(E)sphere{z+E*y*5e-3.04rotate-z*E*6pigment{rgbt#end{
20*y-10#local n=162;1}#while(n)#local n=n-.3;G(n)x}}G(-n).7}}#end//GregE
Subject: Re: Issues with area lights and specular highlights
Date: 11 Mar 2003 11:11:20
Message: <3e6e0aa7@news.povray.org>
  There's currently no way of getting highlights of an area light (instead
of a point light) in such way that the rendering times will not increase
dramatically.
  You can get good arealight-highlights by using a grid of point lights,
but this would completely remove the advantage of adaptive supersampling
in the area_light, thus resulting in dramatical increase of render time.
  It probably wouldn't be too difficult to add support for
arealight-highlights to the current mechanism without slowing down the
rendering unacceptably. However, there might be some non-trivial issues
in this.
Date: 11 Mar 2003 16:52:01
Message: <3e6e5a81$1@news.povray.org>
Would rendering times increase dramatically if just the diffuse component
was correctly calculated with an area light?
Date: 11 Mar 2003 17:34:16
Message: <3e6e6468@news.povray.org>
  I don't see why. There really isn't much difference between diffuse
and specular lighting, they simply use a bit different formulas.
