POV-Ray : Newsgroups : povray.advanced-users : Using Conditional statements with Isosurfaces (Help) Server Time
11 Jan 2025 16:52:35 EST (-0500)
  Using Conditional statements with Isosurfaces (Help) (Message 1 to 4 of 4)
Subject: Using Conditional statements with Isosurfaces (Help)
Date: 11 Oct 2003 12:16:32
Message: <uoagovso6q5nld89k7rkg16vgm16fpmjld@4ax.com>
I'm wondering if it's possible to have an isosurface where a base
function has a one of two or more functions subtracted (or added)
based on the y value. I'm sure I remember seeing such a thing in the
original isosurface patch for pov 3 by R suzuki. I'm thinking of
something like the following
isosurface{
                  function{
			f_base(x,y,z)
		      #if (y>0.5)
			-function{f_detail_1(x,y,z)*.15}
		      #else
			-function{f_detail_2(x,y,z)*.15}
	     texture(.....}
But this dosn't seem to work!
Does anyone know of a way to achieve the same result ?
Thanks i advance
Rob Richards
Subject: Re: Using Conditional statements with Isosurfaces (Help)
Date: 11 Oct 2003 12:26:22
Message: <Xns9411BB9353BFDseed7@netplex.aussie.org>
select may be the thing you're looking for:
"6.1.3.6  Float Functions" select(A, B, C [,D]).
Ingo
Date: 11 Oct 2003 13:09:44
Message: <v0ql51-nji.ln1@triton.schunter.etc.tu-bs.de>
Rob Richards wrote:
ingo's tip is the most efficient solution, alternatively you can also use:
function{
   f_base(x,y,z)
   -(y>0.5)*f_detail_1(x,y,z)*.15
   -(y<=0.5)*f_detail_2(x,y,z)*.15
You should also note that f_detail_1 and f_detail_2 will have to return
the same value on the y=0.5 plane, otherwise you will have a function
with infinite gradient.
Last updated 2 Sep. 2003 _____./\/^>_*_<^\/\.______
Date: 11 Oct 2003 13:13:06
Message: <3f883a22@news.povray.org>
In article <uoagovso6q5nld89k7rkg16vgm16fpmjld@4ax.com> , Rob Richards
This is an illusion, you cannot have seen it because neither they syntax you
show makes any sense or did it ever exist.
As already pointed out by others, "select" is the way to go.
    Thorsten
e-mail: tho### [at] trfde
