POV-Ray : Newsgroups : povray.advanced-users : function optimization question Server Time
23 Feb 2025 01:28:57 EST (-0500)
  function optimization question (Message 1 to 10 of 65)
Subject: function optimization question
Date: 15 Mar 2002 05:15:24
Message: <s4i39u0a519jemevbcmh1fuv2fb6e0du3a@4ax.com>
I wonder if this is optimized if functions evaluator:
select(
  x*Ey+y*Ex-R1*Ex,
  select(
    z+3*x.
    x*Ey+y*Ex-R1*Ex,
    123
 17
Note expression "x*Ey+y*Ex-R1*Ex" appear twice. How many times is it
calculated ?
ABX
Subject: Re: function optimization question
Date: 15 Mar 2002 06:31:30
Message: <3c91db92$1@news.povray.org>
> calculated ?
Twice. The function compiler cannot optimise common subexpressions and it is
unlikely this feature will be added to it in time for a 3.5 release because
it is very complex and would require another intermediate code
representation layer.  The (current) function compiler has no layer suitable
for general optimisations because it performs similfications and elimination
of constants in the expression tree.  That tree is then turned into function
VM instructions, which is nearly trivial because no complex language
constructs (which would benefit from such further optimisation as well) are
supported by the compiler.
    Thorsten
Date: 15 Mar 2002 13:49:14
Message: <5fg49ucdqt4o5ormk2g75rcckq30o1s4pl@4ax.com>
On Fri, 15 Mar 2002 12:33:16 +0100, "Thorsten Froehlich" <tho### [at] trfde>
> > calculated ?
Then it is feature request for 4.5 since 4 will by much more complex task
around rewriting.
As I remember text output of function parser - there were some kind of float
variables/registers/stack entries. I though that every such float has
dictionary feature (similiar to dictionary used gif coding) where every float
has preprocessed string (without whitespaces) with syntax used to build this
expression. So when new expression is calculated then it is verified with
dictionary and use reference to ready float. But my imagination was probably
far from implementation so forget it.
ABX
Date: 15 Mar 2002 15:01:50
Message: <3c92532e$1@news.povray.org>
Sadly, it isn't that simple.  The internal representation is a tree so finding
a subexpression would require to compare every possible subtree of the
function with every other possible subtree.  This task gets very complex
quickly.  That is why there is usually an intermediate representation more
suitable for this "kind of pattern matching" in advanced compilers.
    Thorsten
e-mail: tho### [at] trfde
Date: 16 Mar 2002 03:20:15
Message: <3c93003f@news.povray.org>
is
because
suitable
elimination
function
are
Hmm. I can see how this would be difficult to do automatically, but is there
any chance that 3.5 or a future version could support something where the
user is able to manually select parts of the function that will appear
later? For instance, if I said something like
function{
    f_noise3d(
        x/sqrt(x^2+y^2+z^2),
        y/sqrt(x^2+y^2+z^2),
        z/sqrt(x^2+y^2+z^2)
then it has to evaluate that one peice three times. I can plainly see that
this will slow it down. So it would be cool if I could say something like
function{
    f_noise3d(
        x/(remember(1): sqrt(x^2+y^2+z^2)),
        y/(recall:1),
        z/(recall:1)
Where the 1 indicates that the remembered item labeled "1" should be
recalled. The syntax I made up here is ugly, but is there any chance of this
functionality appearing in the future?
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 16 Mar 2002 09:20:33
Message: <3c9354b0@news.povray.org>
What you want is simple: Support for defining variables inside functions.
Date: 16 Mar 2002 10:01:57
Message: <3c935e65@news.povray.org>
All we miss then yet is only iteration/recursion inside of these functions, and
they're turing-complete ...
(I know, the language itself is already, but function themselfes are not, are they ?)
Date: 16 Mar 2002 10:19:01
Message: <3c936264@news.povray.org>
  Imagine the mandelbrot pattern defined as a function... Or any other
fractal whatsoever.
Date: 16 Mar 2002 10:57:49
Message: <3c936b7d$2@news.povray.org>
But it would be quite a high risk, to get a stack overflow ...
As I understood, functions are more deeper embedded in POVRay, than macros ...
so there probably would be a need for extra checkings, to make functions, not to block
the whole system ...
Imagine a function that looks up, because of a infinite-loop, that gets computet first
time at 50% of an Image ... (this image
rendered at 2pps) ...
how will you tell, that it's the function, dooing an infinite loop, and not "only the
image with a bit of
media/refraction/any-other-slow-feature" ?
I think it would be _very_ powerful, but it would lead to even more headaches than we
have already ...
I think you all know what I mean ... <looking into p.b-t> ....
Date: 16 Mar 2002 14:21:26
Message: <3c939b36@news.povray.org>
  It would just give a "max recursion depth limit reached" error. Nothing
fancy.
  Of course this limit should be something usable, eg. at least hundreds or
better some thousands.
  Naturally if some type of iterative loop is implemented, then recursion
will not be needed.
