POV-Ray : Newsgroups : povray.advanced-users : Generating vectors for area lights. Server Time
23 Aug 2025 14:54:03 EDT (-0400)
  Generating vectors for area lights. (Message 1 to 4 of 4)
Subject: Generating vectors for area lights.
Date: 18 Feb 2003 08:02:07
Message: <pan.2003.02.18.13.06.37.875441@midcoast.com.au>
I am trying to determine
the vectors for an area light give that I have two
and from points and a desired width and height for
the area light.
Subject: Re: Generating vectors for area lights.
Date: 19 Feb 2003 09:58:38
Message: <3e539b9e$1@news.povray.org>
"Danni Coy" <rgc### [at] midcoastcomau> wrote in message
news:pan### [at] midcoastcomau...
> the area light.
I'm not sure I understand what you are asking for, but have you checked out the
"orient" keyword for area lights?
Date: 21 Feb 2003 02:20:34
Message: <pan.2003.02.21.07.25.06.446743@midcoast.com.au>
I am writing a plugin and I am not certain of how to
use the two vector statements in the area light setup.
I need to generate these after the user has specified the
to and from points of the light and the height and width of
the area plane.
Date: 21 Feb 2003 06:03:16
Message: <3e560774@news.povray.org>
> the area plane.
  You can create the area light at the origin, use the Point_At_Trans()
macro to reorient it so that it heads to the correct direction and then
translate it to its place.
  It could look like this:
light_source
{ 0, COLOR
  area_light x*WIDTH, z*HEIGHT, ACCURACY, ACCURACY
  adaptive ADAPTIVENESS
  Point_At_Trans(TO-FROM)
  translate FROM
