POV-Ray : Newsgroups : povray.advanced-users : Vector components to function in isosurface Server Time
12 Oct 2025 22:45:42 EDT (-0400)
  Vector components to function in isosurface (Message 1 to 5 of 5)
Subject: Vector components to function in isosurface
Date: 28 Jan 2004 09:39:20
Message: <opr2hpnwsx0x9foi@news.povray.org>
I tried to use a component from a vector and pass it to a function in an
isosurface, and the parser returned an error. Se minimal scene below. The
parser seems to confuse the notations k.u (component of a vector) and x
(variable for the isosurface). Is this a "feature" or a bug? Or have I
misunderstood something?
***Minimal scene***
#declare Function = function(u, v) {u*v}
#declare k = <1, 1>;
isosurface {
	function {y-Function(k.v*x, k.u*z)}
***Output***
isosurface {
function {y-Function(k <----ERROR
Parse Error: Expected 'operand', uv vector identifier found instead
Returned from renderer with error status
The workaround I figured out was to declare the vector components to
variables:
#declare ku = k.u;
#declare kv = k.v;
and then everything works fine:
isosurface {
	function {y-Function(kv*x, ku*z)}
light_source{20*y,1}#macro _(M,X,Y,P)#macro L(N,D)#if(N)#declare
P=P+D;box{-
0.5,0.5translate z*mod(9*P.gray,4)pigment{rgb P}rotate 45*x+clock*y
translate
P}L(N-1,D)#end#end#if(M)L(mod(M,8)<mod(X,3)mod(Y,3)1>-1)_(div(M,8)div(X,3)div
(Y,3)P)#end#end _(2301603551,12850,60365,20*z-5*x)plane{y,-9pigment{rgb 1}}
Subject: Re: Vector components to function in isosurface
Date: 28 Jan 2004 09:55:41
Message: <04jf10p2q3s1puuun2c6u12u79unebdec1@4ax.com>
On Wed, 28 Jan 2004 16:39:22 +0200, Mikael Pohjola <emp### [at] cchutfi> wrote:
Feature. Functions syntax has separated syntax description in manual.
> isosurface {
You have to workaround it with additional float variables.
  function {
    #local kv = k.v;
    #local ku = k.u;
ABX
Date: 28 Jan 2004 10:10:06
Message: <5lvke1-rlu.ln1@triton.imagico.de>
> The parser seems to confuse the notations k.u (component of a vector)
> and x (variable for the isosurface). Is this a "feature" or a bug? Or
> have I misunderstood something?
This is a feature, vectors are not allowed in user defined functions.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 29 Jan 2004 09:18:54
Message: <opr2jjdwem0x9foi@news.povray.org>
On Wed, 28 Jan 2004 16:04:37 +0100, Christoph Hormann
>> an isosurface, and the parser returned an error. Se minimal scene
>> below. The parser seems to confuse the notations k.u (component of a
>> vector) and x (variable for the isosurface). Is this a "feature" or a
>> bug? Or have I misunderstood something?
> Christoph
Yes, I know that vectors are not allowed in user defined functions, but
why are not vector components?
If V = <a, b, c>, then V.x does not return <a, 0, 0>, but a.
What is the difference with a component of a vector and a float? (I guess
it have something to do with the parser and inner representation??)
I got my answer already from ABX, and I am happy with the workaround.
P=P+D;box{-
translate
Date: 29 Jan 2004 09:38:11
Message: <fa6i10tsferpa13179mlhe3gtfce2jicot@4ax.com>
On Thu, 29 Jan 2004 16:18:58 +0200, Mikael Pohjola <emp### [at] cchutfi> wrote:
Dot operator is reserved for access to components of vector/color functions.
Adjustement to vectors is not that simple there because function parser is
separated to the SDL parser. You have to remember that function code has (in
design) posibility to be precompiled int almost native machine code.
ABX
