hi,
do you think i'ts possible to use this kind of equation to make pov object :
x = f(u,v)
y = g(u,v)
z = h(u,v)
and how ?
thanks for your ideas.
Kurts wrote:
> hi,
> x = f(u,v)
> y = g(u,v)
> z = h(u,v)
> and how ?
Looks like a parametric:
http://www.econym.demon.co.uk/isotut/parametric.htm
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
in news:kurtzlepirate-2EFE3A.19022226022004@news.povray.org Kurts
> object :
> x = f(u,v)
> y = g(u,v)
> z = h(u,v)
Looks like a parametric object, section 6.5.5 from the docs, or as a macro
http://members.home.nl/seedseven/#param
Ingo
Wasn't it Kurts who wrote:
>hi,
> x = f(u,v)
> y = g(u,v)
> z = h(u,v)
> and how ?
Those are called parametric equations, and the relevant section of the
documentation is "6.5.5 Parametric Object". It may help to have looked
at isosurfaces before studying this section.
See also the parametric page of my isosurface tutorial
<http://www.econym.demon.co.uk/isotut/parametric.htm>
and the page on Ingo Janssen's "param.inc" which uses a similar syntax
to generate a mesh2 object of the same shape.
<http://www.econym.demon.co.uk/isotut/param.htm>
Mike Williams
Gentleman of Leisure
thanks mike et christoph
i'will explore this ways
In article <Xns949BC6ADC2719seed7@news.povray.org>, ingo <ing### [at] tag povray org>
> > object :
> > x = f(u,v)
> > y = g(u,v)
> > z = h(u,v)
> Ingo
thanks ;-)
"Kurts" <kur### [at] yahoo fr> wrote in message
news:kurtzlepirate-2EFE3A.19022226022004@news.povray.org...
> hi,
> x = f(u,v)
> y = g(u,v)
> z = h(u,v)
> and how ?
I would advise against using separate functions or macros to create the
object, however. A consolidated macro that creates V = F(u,v), where V is a
vector and F a vector function, is actually easier conceptually. You can
still calculate all of the components individually within the macro, but you
can also bring vector math to bear, in effect wrapping an object around a
spline if needed.
