POV-Ray : Newsgroups : povray.advanced-users : Depth-based camera normals? Server Time
21 Dec 2025 10:50:27 EST (-0500)
  Depth-based camera normals? (Message 1 to 4 of 4)
Subject: Depth-based camera normals?
Date: 5 Sep 2000 12:30:01
Message: <jerry-EA4D38.09300205092000@news.povray.org>
I was at the Frida Kahlo "and friends" exhibit here in San Diego on
Sunday, and one of the paintings got me to thinking about an effect I'd
like to be able to do in POV: a normal on the camera, where the
intensity of the normal change is based on the distance from the camera
to that point in the image. (Even better would be where the intensity of
the normal change is based on the distance between that point in the
image and the focal point.)
So that, for example, a 'checker' normal could be applied to the camera,
and the main focus of the image would receive practically no normal
variation, but items far away from that object would receive heavy
normal variation.
Is there a way to do this in current POV or its variations?
Jerry
Subject: Re: Depth-based camera normals?
Date: 5 Sep 2000 12:49:56
Message: <39b52434$1@news.povray.org>
That's a neat, if obscure, idea. I have difficulty imagining what the
results might look like, but it would be sure to be interesting.
Date: 5 Sep 2000 13:13:23
Message: <chrishuff-D9D0E4.12150505092000@news.povray.org>
I think a more general feature would be a "distance" pattern, which
would sort of use a z-buffer to get the pattern values. You could then
use the existing camera normal feature with a normal controlled with the
distance pattern to get the same effect.
There could be two variations of this pattern: distance from camera, and
distance from start of ray.
Christopher James Huff
Date: 5 Sep 2000 14:00:35
Message: <39B51B11.4D7B0ECA@peak.edu.ee>
Not directly, as far as I can see. But perhaps this would work:
1) get Z-buffer (depth) output with MegaPOV's "Depth" post-process
2) in a paint program, use this as a mask for the camera normal pattern
3) apply the resultant image as the camera normal
Margus Ramst
