POV-Ray : Newsgroups : povray.advanced-users : too many nested objects Server Time
14 Oct 2025 03:33:18 EDT (-0400)
  too many nested objects (Message 1 to 5 of 5)
Subject: too many nested objects
Date: 10 Mar 2001 17:17:19
Message: <gf6lat0hloau30o2s0jcpob7ni47arna6s@4ax.com>
Why do I get the error 'Too many nested objects'? I've got 4000 simple
objects generated in a while-loop. (MegaPOV 0.7)
sig
ICQ 74734588
Subject: Re: too many nested objects
Date: 10 Mar 2001 18:37:32
Message: <3AAABBCA.724FB2A1@peak.edu.ee>
Without seeing the code, my first guess would be that you forgot the closing
bracket in the object (assuming the object is a CSG of sorts).
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 10 Mar 2001 18:48:41
Message: <3aaabd58@news.povray.org>
Sigmund Kyrre Aas <as### [at] studntnuno> wrote:
: Why do I get the error 'Too many nested objects'? I've got 4000 simple
: objects generated in a while-loop. (MegaPOV 0.7)
  You ask a question and then answer it? ;)
  Without seeing the code is hard to say anything.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 10 Mar 2001 22:16:01
Message: <hgrlatgmqkedevi6lqk1btd0hssaeij238@4ax.com>
On Sat, 10 Mar 2001 23:19:08 +0200, Sigmund Kyrre Aas
Maybe you have your 'union' statement within the while loop?
Peter Popov ICQ : 15002700
Date: 11 Mar 2001 15:12:03
Message: <cjinatghbcig58ajts1ciocrapqo41rd2g@4ax.com>
Nope, no csg. The syntax is as follows:
while
 while
  while
    $d=d+(.8+.2*rand(R3))*.03;
    sphere {d/2 Pos}
    $Pos = newpos(d,Pos)
  end
end
end
The scene parses successfully if I replace line 4 with for instance
$d=(.8+.2*rand(R3))*.03;
Limitation or bug? I don't know, but the syntax above turned out to be
wrong.. it should be
while
 while
  while
    sphere {d/2 Pos}
  end
end
end
which works! :)
ICQ 74734588
