POV-Ray : Newsgroups : povray.advanced-users : MegaPOVPlus 0.3.1 released Server Time
15 Mar 2026 08:55:33 EDT (-0400)
  MegaPOVPlus 0.3.1 released (Message 1 to 1 of 1)
Subject: MegaPOVPlus 0.3.1 released
Date: 10 Sep 2000 16:23:08
Message: <chrishuff-CF0B88.15245710092000@news.povray.org>
This version plugs several memory leaks and adds some new features to
the glow patch. A Mac application, source code, and documentation have
been uploaded, I am working on updated demo scenes, and I will post a
Windows version as soon as someone e-mails me one. Also, I made sure to
use different file names this time, so there shouldn't be that sillyness
with downloading a cached version of the old files which happened last
time.
http://homepage.mac.com/chrishuff/povpatch.html
BTW, I hope I set this post up right this time...replies should go to
povray.unofficial.patches now, instead of being scattered across the
newsgroups.
Christopher James Huff
Subject: Re: MegaPOVPlus 0.3.1 released
Date: 10 Sep 2000 22:19:25
Message: <l8gorso88hlbd57e2qrognoorkkue25j2t@4ax.com>
>newsgroups.
  Well, let's find out... <s>
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 12 Sep 2000 01:17:59
Message: <39BDBC96.89EDEBFD@kh.rim.or.jp>
Dear Mr. Chris Huff
I am compiling Mega POVPlus0.3.1 under MrC in MPW.
The glow functions work fine,but a below file of IRTC 8/2000 crashes.
  "Sinking" ("Naufragio")
  Raytraced with MegaPOV 0.5a
  Jaime Vives Piqueres, (?)2000.
  Entry for the 07-08-2000 round of the IRTC, topic "SEA".
But crashes place different MPW and your Official like MegaPOV 0.3.1.
And Mega POVPlus 2.05 work fine the above file.
Best Regards
Y.Tanabe
Kobe,Japan
tec### [at] khrimorjp
> time.
> newsgroups.
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 12 Sep 2000 23:44:08
Message: <39BEF817.2AB0053E@kh.rim.or.jp>
Dear Mr. Chris Huff
under MPW MrC compiler work glow and #set function well and blob does not
crash.
use MegaPOVPlus3.01 files as follows and other MegaPOVPlus2.05 files
glow.c
glow.h
lighting.c
vbuffer.c
modify files for MegaPOVPlus2.05 to glow and #set
frame.h
add:
#define SetPatch /*Chris Huff 2000.8.30*/
#define GlowPatch /*Chris Huff 2000.9.01*/
parse.c
add:
#ifdef GlowPatch
#include "glow.h"
#endif
change:
from
static void  Parse_Warp(WARP **Warp_Ptr);
to
add:
static OBJECT *Parse_Light_Source(void)
#ifdef GlowPatch
CASE(GLOW_TOKEN)
 GLOW  *NewGlow = Create_Glow();
 Assign_Colour(NewGlow->Colour,Object->Colour);
 Assign_Vector(NewGlow->Center,Object->Center);
 Parse_Glow(NewGlow);
 Add_Glow(NewGlow);
END_CASE
#endif
add:
OBJECT *Parse_Object(void)
#ifdef GlowPatch
CASE(GLOW_TOKEN)
 Add_Glow(NewGlow);
END_CASE
#endif
add:
void Destroy_Frame(int destroyAllObjects)
 #ifdef GlowPatch
    Destroy_Glow_List(Frame.Glows);
    Frame.Glows = NULL;
 #endif
add:
static void Frame_Init(void)
 #ifdef GlowPatch
    Frame.Glows = NULL;
 #endif
change:
#ifdef SetPatch
void Parse_Declare(int Modify_Only)
#else
void Parse_Declare(void)
#endif
add and change:
/*Chris Huff 2000.8.30 - added #set */
#ifdef SetPatch
  Local_Flag = (Token.Token_Id == LOCAL_TOKEN || Token.Token_Id ==
PERCENT_TOKEN);
  if(Local_Flag)
     Local_Index = Table_Index;
  else
     if(Token.Token_Id == SET_TOKEN || Modify_Only == TRUE)
      /*Search for most recent table with an identifier with this name Parts
copied from Read_Symbol*/
    int Idx;
    int Found = FALSE;
      Get_Token();
     /* Search tables from newest to oldest */
     for(Idx = Table_Index; Idx > 0; Idx--)
         if(Find_Symbol(Idx,Token.Token_String) != NULL)
         Local_Index = Idx;
         Found = TRUE;
         break;
     if(Found != TRUE)
      Error("#set cannot assign to uninitialized identifier
%s.\n",Token.Token_String);
      Unget_Token();
     else
      Local_Index=1;
#else
  if (Local_Flag = (Token.Token_Id == LOCAL_TOKEN || Token.Token_Id ==
PERCENT_TOKEN))
  else
     Local_Index = 1;
#endif
parse.h
add:
#ifdef SetPatch
  SET_TOKEN,
#endif
#ifdef GlowPatch
  GLOW_TOKEN,
#endif
change:
#ifdef SetPatch
void Parse_Declare(int Modify_Only);
#else
void Parse_Declare(void);
#endif
povray.h
add:
#ifdef GlowPatch
#include "frame.h"/*Needed for GlowPatch definition*/
#endif
add and change:
#ifdef GlowPatch
typedef struct Glow_Struct GLOW;
#endif
struct Frame_Struct
  CAMERA *Camera;
  int Screen_Height, Screen_Width; /* OPTIONS */
  int Number_Of_Light_Sources;
  LIGHT_SOURCE *Light_Sources;
#ifdef GlowPatch
  GLOW * Glows;
#endif
  OBJECT *Objects;
  DBL Atmosphere_IOR, /*DSW*/Atmosphere_Dispersion,/*---*/
Antialias_Threshold;
  COLOUR Background_Colour;
  COLOUR Ambient_Light;
  COLOUR Irid_Wavelengths;
  IMEDIA *Atmosphere;
  FOG *Fog;
  RAINBOW *Rainbow;
  SKYSPHERE *Skysphere;
#ifdef ParticlePatch
  PARTICLE* Particles;
#endif
render.c
add:
#ifdef GlowPatch
#include "glow.h"
#endif
add:
DBL Trace(RAY *Ray, COLOUR Colour, DBL Weight, INTERSECTION *Inter)
#ifdef GlowPatch
 Do_Glow(&Best_Intersection, Ray, Colour);
#endif
tokenize.c
add:
#ifdef SetPatch
  {SET_TOKEN, "set"},
#endif
#ifdef GlowPatch
  {GLOW_TOKEN, "glow"},
#endif
add:
#ifndef SetPatch
static SYM_ENTRY *Find_Symbol(int Index, char *s);
#endif
add and change:
#ifdef SetPatch
SYM_ENTRY *Find_Symbol(int Index,char *Name)
#else
static SYM_ENTRY *Find_Symbol(int Index,char *Name)
#endif
add and change:
void Parse_Directive(int After_Hash)
#ifdef SetPatch
    CASE3(DECLARE_TOKEN, LOCAL_TOKEN, SET_TOKEN)
#else
    CASE2 (DECLARE_TOKEN,LOCAL_TOKEN)
#endif
add and change:
#ifdef SetPatch
         Parse_Declare(FALSE);
#else
         Parse_Declare ();
#endif
add and change:
static int Parse_Assignment()
#ifdef SetPatch
#else
         Parse_Declare ();
#endif
tokenize.h
add:
#ifdef SetPatch
SYM_ENTRY *Find_Symbol(int Index,char *Name);
#endif
Best Regards
Y.Tanabe
Kobe,Japan
Date: 13 Sep 2000 12:38:14
Message: <39BFAD85.AB915FC4@kh.rim.or.jp>
Dear Mr. Chris Huff
I think main problem (blob's crash) is
#define ProximityPatch
for OBJECT and METHOD.
This will break down stack of memory with push or pull or blockmove.
Best Regards
Y.Tanabe
Kobe,Japan
Date: 14 Sep 2000 06:53:10
Message: <chrishuff-E4FADB.05550414092000@news.povray.org>
In article <39BFAD85.AB915FC4@kh.rim.or.jp>, tec### [at] khrimorjp
wrote:
> Dear Mr. Chris Huff
The proximity pattern patch is my main suspect, but I couldn't figure
out why it would cause the other functions to not work right. I haven't
had much time to devote to it yet, though...maybe this weekend.
Date: 15 Sep 2000 00:16:44
Message: <39C1A2BB.3C76B5EB@kh.rim.or.jp>
Dera Chris
I am testing many files under Mega 2.05 + glow and #set.
So I notice blob_pigment does not work and blob_pattern is a little
different.
Of course comapre them with Mega 3.0.1.
I tried your BLOB in frame.h change to BLOB_OBJ,but compiler can not find
problem.
I will continue check more for resolve blob' crash.
See You
Y.Tanabe
Kobe,Japan
Date: 15 Sep 2000 06:51:47
Message: <chrishuff-A94C95.05534315092000@news.povray.org>
In article <39C1A2BB.3C76B5EB@kh.rim.or.jp>, tec### [at] khrimorjp
> different.
They were both changed to act a little more like the blob object and the
code was cleaned up a bit. I have had another report of trouble with the
blob_pigment, I haven't had a chance to look at it yet.
> problem.
That was just a fix for a problem with compiling on Windows, it does not
affect Macs and is not the cause for the crash.
It turns out that it was most likely caused by a fix for a memory leak
that doesn't exist in MegaPOV 0.5a. Basically, the UV-mapping
transformations were copied twice before, and the fix was to simply
delete the second one. However, the first one was removed in more recent
versions of MegaPOV...so anything accessing UV-mapping transformations
of objects which had been copied got bad data.
