POV-Ray : Newsgroups : povray.advanced-users : format of hf_gray_16 .bmp files? Server Time
18 Nov 2025 17:24:21 EST (-0500)
  format of hf_gray_16 .bmp files? (Message 1 to 10 of 27)
Subject: format of hf_gray_16 .bmp files?
Date: 7 Jul 2005 01:23:44
Message: <amepc191ufv40289ocd45u5qragqrhrm1j@4ax.com>
I generated a test gray-level image with hf_gray_16. This created a "image.bmp" file.
The
documentation says that this is a "special 16 bit grayscale". I looked into this file
and it seems
to be really an 8-bit file with all of the r-g-b values equal for each pixel. Is that
indeed the
format of these files? I want to write some c++ code to generate these height field
files that
povray can use.
thanks,
Ralph
Subject: Re: format of hf_gray_16 .bmp files?
Date: 7 Jul 2005 03:57:29
Message: <$KHMtEAs$NzCFwdu@econym.demon.co.uk>
>file. The
>file and it seems
>that indeed the
>field files that
>povray can use.
It's not particularly easy to find the bit in the documentation that
says that only the TGA file format supports the storage of hf_gray_16
data.
If you switch on hf_gray_16 and use a file format that can't store it,
then you just get a grey image.
If you look at a hf_gray_16 TGA file with an image editor, you'll see
that all the colours are wrong. The R and G channels are being used to
store high and low bytes of the 16-bit data, but the image editor
doesn't know that. If you look at any image in any other format that's
created with hf_gray_16, you'll see that that doesn't happen.
There are no hf_gray_16 BMP files.
The documentation suggests that you can use an externally generated PPM
file to store suitable 16-bit data, but PPM files created by POVRay with
hf_gray_16 switched on are not in this format (and they're not simple
grey images either). Creating such a PPM image is going to be a little
tricky, because you've also got to somehow set the undocumented marker
that tells POV to treat the RGB data as 16-bit grey (there's nothing in
the height_field syntax that specifies the hf data format, so POV has to
obtain that information from the file).
Mike Williams
Gentleman of Leisure
Date: 7 Jul 2005 04:20:02
Message: <daiobu$52f$1@chho.imagico.de>
> data.
That's not quite correct - hf_gray_16 is supported for PPM (leading to
PGM) and PNG output as well (and it makes most sense for those formats).
Why do you think so?  Last time i checked POV-Ray generated correct
binary 16bit PGM with hf_gray_16 and +fp.
POV-Ray reads 16 or 8 bit PGM images without problems.  Nothing
undocumented there AFAIK.
http://www.tu-bs.de/~y0013390/ (Last updated 01 Jul. 2005)
Date: 7 Jul 2005 09:09:13
Message: <m1Z6CLAWlSzCFwt6@econym.demon.co.uk>
When I use POVRay to generate a hf_gray_16 TGA file, it works as a
height_field.
When I do exactly the same thing with a PPM file generated with
hf_gray_16 and +fp. I get an error "Parse Error: File is not in PPM
format (type 53)" when I try to use it as a height_field. (POVRay 3.6
Windows 98se).
Some image editors think that the hf_gray_16 PPM file has 8 bits per
pixel (and don't display it correctly). Other image editors think that
it's an 8-bit greyscale PGM file with an incorrect extension (and do
The documentation only mentions generating TGA hf_gray_16 files from
within POV. The only bit that mentions using 16-bit PPM files says that
they can be "generated with special custom-made programs".
However, the significant point for the original poster is that you can't
do it with BMP files.
Mike Williams
Date: 7 Jul 2005 10:12:09
Message: <19dqc1pcd64c36dn0odpm39vvog0ok5ods@4ax.com>
On Thu, 7 Jul 2005 14:08:38 +0100, Mike Williams <nos### [at] econymdemoncouk> wrote:
I don't understand."image.pov created image.bmp. Image.pov contains
global_settings {
	assumed_gamma 2.2
	hf_gray_16
There is no image.tga.
Then I run test.pov to use this bmp file as a height field:
height_field  {
   //tga "image.tga"		// created from "image.pov"
   sys "image.bmp"
   smooth
   	gradient y
   	color_map {
      	[0.00 color rgb <  0,   0, 0.4>]
      	[0.05 color rgb <  0, 0.2,   0>]
      	[0.60 color rgb <1.0, 1.0, 1.0>]
      	[1.00 color rgb <1.0, 1.0, 1.0>]
   finish {
		specular 0.5
		roughness 0.05
	normal {
		bozo
		translate <0, 1.23456, 0>
		scale 0.002
   translate <-.5, 0, -.5>
   scale <17, 1.75, 17>
	rotate<-90, -45, 0>
It works. So, I think that you CAN use .bmp files as height fields. But I also think
that they only
have 256 gray levels since for all pixels r = g = b as far as I can tell.
If I switch to .tga files would I get 65,536 gray levels?
But I would still like to be able to create hf_gray_16 files externally. It sounds
like the format
of such .tga files might not be documented.
Ralph
Date: 7 Jul 2005 12:50:02
Message: <dajmek$bqc$1@chho.imagico.de>
> height_field.
> Windows 98se).
As said with hf_gray_16 POV-Ray generates PGM files - you have to
specify them as 'pgm' in the heightfield statement.
A lot of image editors don't read PPM/PGM files according to the specs.
Date: 7 Jul 2005 13:00:02
Message: <dajn1h$btt$1@chho.imagico.de>
> global_settings {
> 	assumed_gamma 2.2
> 	hf_gray_16
You can find how to specify the file format to generate on
http://www.povray.org/documentation/view/3.6.1/219/
like the format
You can find the file format specifications for PGM on:
http://netpbm.sourceforge.net/doc/pgm.html
I would be really astonished if you could find a similarly complete
specification for the BMP format.  As i have said a lot recently using
BMP as an image file format is rarely a good idea (no matter if for
renders or for heightfield data).
Date: 7 Jul 2005 13:12:51
Message: <42cd6293@news.povray.org>
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/gdi/bitmaps_4v1h.asp
Because, of course, we all know that Microsoft hates developers and
wouldn't want to let anyone else create software that can export to
their proprietary formats, naturally.  That's why when you search for
"bitmap file" nothing comes up in MSDN. ;-)
     The samba was clearly inspired
     by the margarita.
Date: 7 Jul 2005 13:50:01
Message: <dajptc$chn$1@chho.imagico.de>
I mean they write "established bitmap file format" - which says it all.
Never try to fool an ex-OS/2 user about there being a kind of standard
in BMP files...
Date: 7 Jul 2005 14:53:46
Message: <42cd7a3a$1@news.povray.org>
> in BMP files...
Oh, you mean OS/2 took a Windows format and modified it, but called it
the same thing, and screwed things up? OK. ;-)
Seriously, they're *all* bitmap formats. I figured you meant the
microsoft bitmap format. Typing "OS/2 bitmap storage" into google and
hitting "I'm feeling lucky" gets you that bitmap format.
     by the margarita.
