POV-Ray : Newsgroups : povray.advanced-users : the new array function Server Time
21 Mar 2026 18:49:20 EDT (-0400)
  the new array function (Message 1 to 4 of 4)
Subject: the new array function
Date: 30 Jun 1999 15:22:34
Message: <Pine.LNX.3.93.990630142006.20055A-100000@alien.ufo.net>
Will the new  array  function (latest pov release) allow you
to define an array of ANY size...say 30 by 200 ?
  Also...is there a tutorial which deals mostly with this function?
thanks, stu7
Subject: Re: the new array function
Date: 30 Jun 1999 15:26:38
Message: <377A6F2B.16B9F776@pacbell.net>
> thanks, stu7
I believe it it limited to a maximum of 5 x n in the format of
<a,b,c,d,e>,
<f,g,h,i,j>,
<k,l,m,n,o>,
etc...
See also the thread I started in this group:
    Subject: Mandelbrots, Rand, and maybe more...
       Date: Fri, 28 May 1999 21:27:56 -0700
 Newsgroups: povray.advanced-users
Ken Tyler
mailto://tylereng@pacbell.net
Date: 30 Jun 1999 16:00:00
Message: <377a7740@news.povray.org>
>> thanks, stu7
><a,b,c,d,e>,
><f,g,h,i,j>,
><k,l,m,n,o>,
>etc...
Why should that be?  You're not limited to a single-dimensional
array, you know.  Consider this example, from the docs:
  #declare Rows=5; #declare Cols=4;
  #declare Table=array[Rows][Cols]
Here are the real limits on arrays, gleaned from the source code:
  - An array may have a maximum of five dimensions.
  - All of the elements in an array must be of the same type.
  - Each dimension may be as large as needed, but the product of the sizes must
    be no greater than the size of a signed int on your architecture.  For most
    current architectures, this is something like 2 billion, so you'll probably
    run out of either time or memory first.
This information is also in the documentation for arrays, except for the maximum
size (probably because it's so ridiculously huge as to not bear mentioning.)
Date: 9 Jul 1999 23:08:52
Message: <B3ACF67B-5C74A@147.109.83.18>
>>> thanks, stu7
>><a,b,c,d,e>,
>><f,g,h,i,j>,
>><k,l,m,n,o>,
>>etc...
[rest snipped]
and if you run out after 5D then:
#declare a_big_array=array[3][3][3][3][3]
#declare another_array=array[2][2]
#declare a_big_array[0][0][0][0][0]=3.141592653589793;
//note you *must* assign values to elements before assigning an array to
//another array's element, otherwise the parser objects when accessing the
//element in the #statistics line below
#declare another_array[0][0]=a_big_array//notionally now a 7D array
#statistics str(another_array[0][0][0][0][0][0][0],3,9)
which allows variable length and dimension arrays... anyone for lists of
vertices?
(note: you can test array elements for the dimensions of the array held in
the element, but testing the containing array doesn't take those dimensions
into account)
As this is undocumented (as far as I can see) it probably isn't a good idea
to build scenes which rely on it, just mentioned it in case someone needs
>5 array dimensions NOW.
Have Fun
Martin
Owner/Operator - Tesseract Computing
<hyp### [at] tesseractcomau> or just reply.
Computer Systems Officer - Tourism Tasmania
<Mar### [at] tourismtasgovau>
I speak for me.
