In article <web.47c2d45def771f4cfddaa4670@news.povray.org>,
nomail@nomail says...
> > > The six vertices are x,y,z,-x,-y,-z, possibly scaled by something.
> > > If you want rounded edges, say with radius R,
> > > then put spheres with radius R at each vertex, a cylinder with radius
> > > R at each edge (or, to save code, a spheresweep
> > > x y (-x) (-y) x z y (-z) (-y) z (-x) (-z) x )
> > > displace the triangle with vertices a,b,c by (a+b+c)*R/sqrt(3) (for
> > > all applicable values of a b and c).
> > > This assumes, that you do not need a solid die, i.e. your textures ar
e
> > > not transparent.
> > Got to be solid, or at least mostly. I need to cave in a set of symbols
> > and lettering.
> In that case replace the triangles with something solid.
> The easiest would be an eight of an octahedron: For the triangle with
> vertices a, b, and c this would be
> intersection {
> plane { -a 0 } plane { -b 0 } plane { -c 0 }
> plane { a+b+c 1/sqrt(3) }
> translate (a+b+c)*R/sqrt(3)
> Keep in mind, though, that carved dice are not considered fair.
> Best,
> Mark Weyer
Decided to use the one in shapes2.inc and just scale it, thought that
means, at some point, lopping edges off and replacing them with
cylinders, etc, to round it. Got a different problem though. The
texture... So far I have this, which I am not real satisfied with:
pigment {marble
turbulence 0.85
color_map {
[0.00 0.40 color rgb <0.66275,0.57647,0.58824>
color rgb <0.65882,0.56078,0.57255>]
[0.40 0.72 color rgb <0.64275,0.55647,0.56824>
color rgb <0.63882,0.54078,0.55255>]
[0.72 0.95 color rgb <0.62275,0.53647,0.54824>
color rgb <0.61882,0.52078,0.53255>]
[0.95 1.00 color rgb <0.57775,0.49147,0.50324>
color rgb <0.57382,0.47578,0.48755>]
What I am trying to do is duplicate the colors in this:
http://everquest.allakhazam.com/pgfx/item_1138.png
but looking more like:
http://everquest.allakhazam.com/pgfx/item_1095.png
Though, in fact, I plan to use "both" color sets for different parts of
the item I am building. And, since this is going to be a *large* object,
I want to make at least one band in it so that, instead of having the
reflective qualities of polished stone, it has granular crystal like
veins, which have a metallic finish. So, what I am looking for is
something like:
pigment {marble
turbulence 0.85
color_map {
[0.95 1.00 color rgbt <1,1,1>
color rgbt <1,1,1>]
finish { stuff to make it polished stone }
pigment {marble
turbulence 0.85
crinkle
color_map {
[0.00 0.95 color rgb <1,1,1>
color rgb <1,1,1>]
//Darkened to enhance the vein like appearance.
[0.95 1.00 color rgb <0.47775,0.39147,0.40324>
color rgb <0.47382,0.37578,0.38755>]
finish { stuff to make it metallic }
Right? Can just try it, but wouldn't mind some input on how to get the
texture itself a bit closer to what I want as well.
void main () {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
