POV-Ray : Newsgroups : povray.advanced-users : Heightfield problem Server Time
18 Dec 2025 00:51:16 EST (-0500)
  Heightfield problem (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Heightfield problem
Date: 17 Feb 2002 10:07:13
Message: <3C6FC70E.72D721D4@pacbell.net>
Lars wrote:
> Any recommendations on good tools to smooth and manipulate 16bit
> grayscale images under win2000?  Photoshop is quite limited in it's
> 16bit handling, and I'm not having any luck with Wilbur--it seems to
> produce a lot of empty images and lose data.  HLA didn't run under
> windows 2000.
Have you looked at Leveller? - http://www.daylongraphics.com/
Ken Tyler
Date: 17 Feb 2002 10:22:00
Message: <3C6FCA97.51D31352@gmx.de>
Lars wrote:
> I'm guessing that probably wouldn't change the boxing effect I see in
> smoothed images, but that might help with trying to get the non smoothed
> image looking less stepped.  That's what I've been trying to do
> recently, but I am having problems finding a good image processing tool
> that can handle 16bit grayscale images.  I've been taking an 1000 x 1000
> 8bit image (TGA converted from a DEM) and upscaling it to 5K x 5K,
> allowing Photoshop to do bicubic interpolation to create the additional
> 16bit data between the original 8 bit image source pixels.
There are various types of so-called 'DEM' data formats which need
different conversion programs.  A lot of them are in a quite simple ASCII
form, but some are more complicated.  Nearly all are 16 bit data in the
original so the 8 bit you get are probably result of the conversion.
> windows 2000.
gforge/HF-Lab should compile with Cygwin without problems.
Last updated 06 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 17 Feb 2002 10:29:05
Message: <MPG.16d96c209cb4c61b989682@news.povray.org>
I downloaded the demo and played with it for a bit, and honestly
couldn't figure too much out!  :)  The cost was an issue for me, so I
didn't look at it too seriously, but I'll look at it a bit further if
you think it will work.
> Have you tried dem2pov?
I haven't--I'll look into it.  I used a DEM->TGA converter to begin
with, but I do need to edit the files after they are converted from
DEM--move features around, adjust them, add new features, etc.  So I
need some way to edit them once they become 16bit files.  (editing them
in 8 bit and then trying to convert them to 16bit after is what I was
doing, but I've been running into the smoothness / stepping issue).
Many of the DEM converters didn't look like an option for me, since I
wouldn't have any way to manipulate the data afterwards.
I saw a couple more programs on the povray.org site, but many were dead
links--earthscape, klevel, smooth, etc.  :(   If I can't find something
that exists already, I might just write my own 8 to 16 bit converter
with smoothing.  Or maybe set up a DOS box to run HLA.
It sounds like the consensus so far is that I should attack this from
the trying to get a smooth 16bit image angle and not use the heightfield
smooth function.  None of my experiments to date have suceeded in
getting the smooth function to work without the boxes effect in some
degree.
Date: 17 Feb 2002 10:36:39
Message: <MPG.16d96dd9f17b4247989683@news.povray.org>
I'm having to deliberately convert them to 8 bit, since that's the only
way I have of editing them after I convert them.  If I had image editing
software that could read and manipulate 16bit grayscale images, I'd
start from there and probably not have the problem at all.  But so far,
I've been unable to find anything that can manipulate 16bit grayscale
images.  I tried UTSCSA's ImageTool 2.0, but it can't handle the large
file sizes needed.
So the lack of a 16bit image editor is the reason why I have to go to 8
bit, edit, then convert to 16, using bicubic interpolation while
increasing the pixel scale to smooth out the results.  But it's not
smoothing enough.  So I need something that can either edit the 16bit
images, or at least run a good smoothing algorithm on the converted
16bit image.
I'm assuming that if I could get the full dynamic range of 16bit
grayscale, my stepping issue should go away.  If not, well, then I'm
back to the drawing board.
Date: 18 Feb 2002 18:44:55
Message: <MPG.16db31d28d1977d6989684@news.povray.org>
Thanks for the suggestions so far.
I've been able to create a full depth, smoothed 16bit test image for the
heightfield.  Unfortunately, even with 16bits, the stepping remains
quite noticable.  I've got many many more steps than before, but they
don't blend and remain quite clear.  The edges of each change in
elevation are highlighted and it looks like a million slug trails over
the landscape--or maybe those architectural models where they make hills
from layers and layers of flatboard.  I think the problem lies in the
terrain is mostly flat, with subtle slow changes in elevation causing
the stepping.  Plus it doesn't seem to smooth between to areas, instead
making a dimensional bump between two values.  Places with more
pronounced altitude changes don't look as bad.  So I think 16bit
elevation data has failed to solve the problem.  It appears I need to
find a way to get smooth to behave, or find a different approach.
Using Heightfield "Smooth" tends to produce a more muddied look-- it
appears as if there are only three levels of lighting--dark, med and
light with no gradation between them.  It looks very posterized.  It's
almost as if the normals are quantized and only allowing for three
levels of specular lighting effect.  Plus the boxes problem remains
(which might be related--more gradations might make the boxes harder to
notice).   I've tried changing my scale factor, in case it was a
precision issue, but no change.
Anyone have any further ideas on heightfield smooth?
Thanks
Lars
Date: 18 Feb 2002 19:19:12
Message: <3c719a00@news.povray.org>
In povray.general Lars <sel### [at] pacbellnet> wrote:
: Anyone have any further ideas on heightfield smooth?
  Did you try with a lower resolution? For example divide width and height
by 10. (You don't have to use it; just try it to see what happens).
Date: 19 Feb 2002 07:17:29
Message: <3c724259@news.povray.org>
Also, if you happen to be on Linux (or some other Gnome-enabled UNIX), you
might want to try
  http://terraform.sourceforge.net
which features a quite-capable terrain editor with some (limited) povray
integration ...
Greetings
--> R
>> windows 2000.
Date: 19 Feb 2002 13:54:50
Message: <MPG.16dc3f5a32807e6d989685@news.povray.org>
do you mean the rendering or the height field source?
Reducing the res of the HF source doesn't change the boxing effect, only
I get larger boxes.  I tried resolutions from 500x500 up to 10000 x
10000, both 8 and 16 bit depths.  They all show the posterization and
boxing when smooth is enabled, just with differing size boxing.
Reducing the rendering output size makes everything lower res, and
eventually the boxes disappear as they become sub-pixel in size.  The
world looks reasonable at 640x480 or whatever, since each box is 0.002
pixels across!  So the scale of the boxes is constant in relation to the
world scale.
Date: 19 Feb 2002 14:31:12
Message: <3c72a800@news.povray.org>
Is it possible to output the HF vertices? If so, you could make the
triangles and figure the normals yourself. The fact that a HF parses so
quickly suggests to me that some type of cheat is used to figure the
normals. If you put the HF where you wanted it and then calculated the
"real" normals, you would surely get a better result.
If not, I think it would be pretty easy to build your own heightfield with
eval_pigment. Haven't tried that, though.
Hope this helps.
 -Shay
Lars <sel### [at] pacbellnet> wrote in message
news:MPG.16d84912e546d13b989680@news.povray.org...
Date: 19 Feb 2002 15:23:56
Message: <chrishuff-3A4433.15234219022002@netplex.aussie.org>
In article <3c72a800@news.povray.org>, "Shay" <sah### [at] simcopartscom>
Or just use one of the height field macros from shapes.inc. ;-)
